I am putting some new batteries on my boat this week. My current system has worked well for years. We have had deep cycle flooded lead batteries last four years. So there is a part of me that is saying "if it ain't broke don't fix it". So let me explain. We are set up with two battery banks on two separate switches. One is a series 24 battery start battery, on its own switch (off/on). The second bank is house and two series 27 batteries in parallel. It is on a 1/2/both/off switch. (see picture called battery wiring) This works well I have no desire to change it. My dilemma is that for charging I have the standard Hitachi 35amp alternator, a 35 watt solar panel, and an ancient 30 amp three output "C-Charger" that I rarely use. I rarely use it because the solar panel generally keeps our batteries topped off. The Charger feeds into a West Marine 70 amp 3 bank battery isolator which feeds to the corresponding battery switches. Both the alternator and solar panel feed into the power source of the isolator. (see the diagram called charger diagram). There is also a photo of the charger and isolator.
So, here are my questions. 1) is there something that I can replace the old diode isolator with that will isolate the batteries and control the charge level of a new charger, the alternator, and solar panel. Would something like this work? http://www.sterling-power-usa.com/ProSplit-RZeroVoltDropMarineBatteryIsolator-12.aspx 2) if there is nothing that can do all three is there something that would control both the alternator and the solar panel? 3) can a charger sense voltage through an isolator?
