Hi all. I was cleaning my bilge, keel bolts, etc. and easily broke the old corroded 6 AWG grounding cable from the FWD most keel bolt. Luckily this happened; once fixed, I noticed the grounding wire running beneath the fiberglass decking, under the base of the compression post, had too much play. I was able to pull it out with no energy; when I did, it was completely corroded. It looks like it wasn't hooked to anything, to begin with.
Question: Under the fiberglass decking, is the grounding wire supposed to be connected to a lightning ground plate; or by bolt/nut via the bottom of compression post? What is your recommendation for the appropriate fix?
See attached pictures. (FYI - I sanded down the copper fitting)
