Catalina pole-based table?
DaveNC
Mar 20, 2018
12
Catalina Capri 26 266 Oriental, NC
Anyone have experience with the Catalina table that is built on the pile and slides up and down? We just bought a Capri 26 and the table is very difficult to loosen and slide up as a table or down for sleeping. It is very heavy and takes two people to lift, and it is a real challenge to get under to unlock or lock it.
Anyone have advice or perhaps ours is missing something.
Thanks
May 20, 2016
3,015
Post a picture of the mechanism - Catalina uses the same parts on many boats with a picture someone without specific knowledge of your Capri might be able to answer
Les
Jul 20, 2005
2,422
Whitby 55 Kemah, Tx
My Hunter has the same type of table. Inside the compression post is a weight attached to a rope which goes through a block and then tied to the table. This weight counters the weight of the table. Maybe your boat is missing the rope or weight?
Does it look like this?
This is with the table off. To use it, I've found I have to push down EXACTLY in the middle. Never had any issue of it popping back up with a little persuasion, also in the middle.
I'm not sure these have blocks, but rather are spring loaded.
DaveNC
Mar 20, 2018
12
I'm going to the boat tomorrow and I will post a picture after that. Thanks
May 7, 2006
249
Catalina 28 Mark 1 New Bern
Dave they are all hard I had the same problem with mine, hull # 172, you need to make sure the screw under table is loose. I have the same problem now on my Catalina 28 if I want to lower it. If you ever come up the Neuse from Oriental I am in FAIRFIELD harbor
May 20, 2016
3,015
Dave the strut inside these columns is held in the center of the column by a thin plastic piece that breaks easily as they age. If this plastic is broken it will be almost impossible to collapse the table for making into a bed. As @Stu Jackson said you need to push in the center. Mine is broken this way, when I get a 3D printer I’m going to print a replacement.
Les
DaveNC
Mar 20, 2018
12
I don't see any place where an internal counter weight wire would have connected to this table. It appears to be simply built around the pole and held up with a screw mechanism. The table is so heavy and the screw is under it, so it takes two people to raise or lower the darn thing. Anyone have a Capri 26? Is it the same?
DaveNC
Mar 20, 2018
12
I don't see any place where an internal counter weight wire would have connected to this table. It appears to be simply built around the pole and held up with a screw mechanism. The table is so heavy and the screw is under it, so it takes two people to raise or lower the darn thing. The pole likely supports the weight of the mast and goes from below the sole to the cabin top.
DaveNC
Mar 20, 2018
12
Anyone with this same boat?
DaveNC
Mar 20, 2018
12
I uploaded the picture from the brochure.
249
Dave there is no counter weight it is only the collar with the screw under table to hold it in place. It is heavy to lift.
peterbud
May 20, 2016
3,015
There should be a strut in there like what holds up hatchback lids. I had mine apart 2 months ago.
Les
DaveNC
Mar 20, 2018
12
PeterBud,
That confirms what I see. Nothing that assists lifting. It's not the best design. Thanks
May 7, 2006
249
Les
Les there is a strut to hold up the sides of the table, but we are talking about raiing and lowering the whole table
May 20, 2016
3,015
my column has a strut inside of it to assist in raising and lowering - looks like a shock absorber.
