I was cleaning my bilge yesterday prior to installing new bilge pump. The wire/cable in the attached pics went through the bilge aft towards the engine. The other cable just like it was cut off at the aft end of bilge. So I pulled the one in question out of the bilge (yea - I should have stopped pulling when I found it had some length, but it was late!). I'd say it is long enough to get aft of the engine (yea - I know - I should have measured it!). Any clue what it is and where it should be connected? The markings on the cover are pretty generic - manufacturer, size, etc. - nothing to give a hint as to its purpose. So, any ideas on where it should be terminated? Is it a grounding cable?
Also, I've not noticed the hose entering the bilge in the past. I've been around in the hull under the v-berth and hanging locker/drawers. Have not seen an origination for this hose in those spaces. It is not the floor drain from the head (which is the one in the bottom of the pic by the keel bolts).
