The contents of your holding tank (into your bowl), or the Gulf of Mexico. Your choice!It shows a lock and an unlock. What am I unlocking?
I can't locate my owners manual- must be on the boat. I do believe that valve is actually an inlet valve to the pump, from the bowl. The piston rod holds the INPUT valve closed so stuff does not back up into the bowl. It works in concert with the joker valve. Personally, I don't think it works that well.. At the end of normal pumping out, at the bottom of the pump stroke, the user simply turns the handle through 90o which locks the piston down onto the base outlet valve, keeping it securely shut. Turning the handle to the normal operating position opens the lock again."
I would agree with that sentiment.Personally, I don't think it works that well.
Do you replace the flapper valve when you replace your joker valve?Personally, I don't think it works that well.
You have it backwards...it keeps back flow (waste left in the toilet discharge line because it's either way too long, runs uphill, insufficient pumping or all of the above) from getting back INTO the bowl.This simple, easy to use, development ensures that even on a poorly installed toilet system, water and waste cannot backflow out of the bowl.
To the guys who say it does not work, is that based on the opinion that the design is flawed, or observation that it fails in real life? Just curious, I’ve never had backflow.Doesn't work.
What he said!Tip: Don't change your joker, O-Rings, check valves just buy this instead.
https://www.amazon.com/gp/product/B001794BS0/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
About $20 more, single change out, less mess.
Jim...
What a GREAT idea! I wonder who came up with that??? ;^)Your wife will love the Raritan PH SuperFlush (also available as a "conversion" that allows you to keep your existing bowl, seat and lid) Raritan PH SuperFlush has a re-designed base that has the same mounting bolt pattern as your Jabsco, but uses the PHII pump that's been the top rated manual toilet for more than30 years. The sbo.com online store can get it for you...give Dave a call for price.
