Ball valves...
NYSail
Jan 6, 2006
3,155
Beneteau 423 Mt. Sinai, NY
Hello all....
Have a bad ball valve that needs to be replaced. Bought a new groco however now find out threads are metric. Should I just start from scratch and replace everything? What have others done?
Thanks!
Gunni
Mar 16, 2010
5,937
Do your research on the GROCO BSPP threaded fittings for the OEM Beneteau through-hulls.
Jun 21, 2004
3,051
Beneteau 343 Slidell, LA
Second Gunni’s recommendation. I just purchased Groco’s fittings with BSPP threads. Not as good as a seacock; however, better than the OEM setup. At least the thru hull fitting, ball valve, and tailpiece are all bronze with matching threads. Purchased directly from Groco.
Aug 22, 2017
1,609
Hunter 26.5 West Palm Beach
You might be able to find thread adapters if you google hard enough. If not, any local machine shop with a thread cutting lathe should be able to make them up for you, in your choice of material.
NYSail
Jan 6, 2006
3,155
Now that was easy....... thanks Gunni and all. Groco shipping everything! Started to panic as boat is heading into water in a couple of weeks.... hate un-closed holes in the bottom!
NYSail
Jan 6, 2006
3,155
So part came in, went to boat and what do you know.... fits. Again thanks for the direction. However, when looking at the set-up it looks like beneteau used different metal for the street elbow and fitting. Also other ball valves that are original all do not look bronz....... or is that just aged (2005).
Thanks
NYSail
Jan 6, 2006
3,155
Beneteau used brass below the water line?? Seems nuts. So this combination.... Brass thru hull and elbow to bronze ball valve is a disaster waiting to happen. And not just that.... if it is the case that Beneteau used all brass fittings below water line then all thru hulls are suspect??
Gunni
Mar 16, 2010
5,937
Beneteau used bronze for the thru-hull, but you don’t know what the previous owner did with fittings beyond that. Looking at the elbow I think I see a fracture in the thread next to the the valve.
Apr 22, 2011
958
I does look like a possible fracture in the thread. Also, the thread area is pinkish in color that could signify dezincification. They may have used a type of bronze that has a higher than normal zinc quantity.
NYSail
Jan 6, 2006
3,155
The pink stuff is a thread sealant..... think the fracture is the light, however I will check closely today when at boat...... cover comes off! Thanks for the good eyes!
NYSail
Jan 6, 2006
3,155
Well that is a relief hearing..... everything on boat is original. All fittings look the same.
Jun 21, 2004
3,051
Don’t know first hand what they used for the thru hull fitting; however, the ball valve was very light in color—doesn’t appear to be bronze.
NYSail
Jan 6, 2006
3,155
A few other ball valves on boat......
Just don’t look like typical marine, however all appear in good shape
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
I have wodered from they day I got my boat why the ball valves appeared to be stainless whilst the through hull fittings were bronze. The boat has only been in fresh water, so no outward signs of corrosion after 13 seasons.
Gunni
Mar 16, 2010
5,937
Typical. If they give you trouble replace them with the new GROCO BSPP valves and fittings. Elegant and improved.
RoyS
Jun 3, 2012
1,742
What thread sealant will you use with straight threads?
