Electronic tank gauge
Feb 23, 2018
52
Hunter 356 Marseille
Hello from Marseille in France,
I have just bought à 356. How accurate are the tank gauges? I don't intend running dry on diesel.... Just curious.
Where Can I access thé diesel tank to inspect for sludge/bacteries?
Great forum I have learn't loads already :)
Bob R.
Jun 5, 2004
161
Marlow-Hunter 40 Pasadena, MD
Hello Secret Sail. I have owned a Hunter 356 for 11 years and sail it on the Chesapeake Bay. I have never relied on the tank gauges. Fortunately the 3 tanks that are monitored are all large enough to not have to worry about fuel, water or waste holding capacity. The diesel tank is easily accessible under the aft bunk and the holding tank is accessible in the starboard transom locker. The water tank is under the V-berth bunk and is not easily accessible.
Where do you keep your new boat in Marseille? My wife and I are going to be in Marseille for a day on April 12 on a Viking cruise ship stop over. We will be in the Vieux Port (Old Port) area in the morning and plan to do some sight seeing along the water front and seeing some the older parts of the City. Is your boat far from the Old Port?
Aug 22, 2017
1,609
Hunter 26.5 West Palm Beach
The accuracy of a tank gauge is usually very good, but it depends on many things. For starters, when the sender is installed, it is common to bend the float arm to give the proper range inside a particular tank. Since this is usually done by hand, using only an eye as a calibration tool, the results can vary. Also, senders can suffer from corrosion as time goes by & loose accuracy.
I constantly monitor the tank gauges when I fill the tanks on any boat, to see if the liquid that I put in matches with the change that I see on the gauge. If something looks funny, I immediately plan a time to take a look.
Back when I flew planes, we never trusted fuel gauges. We always checked the wing tanks visually with a stick before taking off. If I plan to take a boat out past VHF range, I continue with this old habit of not trusting the gauge.
The only gauge that I really trust is a sight glass. Sadly, that is not a viable option on most boats. Carrying a 5-gallon can of back up fuel is an option that often gives me comfort. In the case of a diesel, you will want to know how to bleed air out of the fuel system in case you do run it dry & need to reach for your can of back up fuel.
Gauges usually work very well, until the day that they don't.
Likes: JamesG161
Aug 22, 2017
1,609
Also, since the OP is in Europe...
I think that the European sending units work backwards from the American ones. I need to look up the actual specifications to give accurate details, but if the gauge goes up when the liquid level goes down, you probably have a mismatch between the sender & the gauge, assuming that your wiring is good.
JamesG161
Feb 14, 2014
8,111
Hunter 430 Waveland, MS
:plus::plus:
I do the same on my landlubber vehicles too.
I have WEMA brand gauges that work on microswitch/float. Their precision is based on level change between switches.
My 50 gal diesel gauge is ±5 gal and I keep 10 gallon in cans aboard.
____
The difference between the two standards is USA has a "live zero". If my Europe standard ones, lose power then it reads like an empty tank.:frown:
That is why they are reversed.
Jim...
Mar 3, 2003
710
Hunter 356 Grand Rivers
I have a 2003 Hunter 356 bought new. I don’t trust the original gauges. I log every hour of my generator and Yanmar and use hours x rate per engine to give a total used. Keep records and you will find you can usually be within a half gallon or less at each refueling. Only time I was off much was when loaded very heavy and cruising. I also at that time had a worn Maxprop. My estimates were off. I now adjust for load and if offshore add .25 gallon per hour for wave action.
senang
Oct 21, 2009
318
hunter 38 Monaco
I do like Jerry. I keep track of engine hours after topping up. I cal it "tank hours". Being also in Europe I multiply by 3 (lt/hr) to get total litres burnt. As a rough guide on my H38, when the gauge says 3/4 I rneckon tank is half full, when gauge is 1/2 I reckon a quarter tank is left.
Mar 20, 2004
1,753
the 356 gauges are reasonably accurate if they are calibrated correctly -you can do that. The fuel gauge is not a float on an arm, it's a cylindrical tube gauge that MAY not go all the way to the bottom of the tank. Under the aft bunk you'll see an access hatch and the sender - removing the sender give you a 4" inspection/cleaning hole. I'm a "trust but verify" guy, I track run hours to calculate fuel use, and then I open the forward cover over the tank and shine a bright light into the tank. when you move the light up and down against the plastic tank, you can see the physical fuel level and get a good idea of the level.
The waste and water tanks use external capacitive senders.
Feb 23, 2018
52
Thanks for all your comments and help. I sailed a Bénéteau 46 to Gibraltar once. 210 litres de fuel. Except the triangular tank prevents the fuel pick UP pipe going to the bottom. So 190 litres available... I am now very more cautious. I note the hours when I fill up. 3lit hour is about average for a yanmar3gm30. I carry 20 litres in à jerrycan in case :)
Aug 22, 2017
1,609
On boats with installed fuel tanks, I usually make up a gauge reading sheet like the one below. This lets me check the accuracy of the gauge each time I fill up. It also gives me a good idea of what the reading actually means so that I can make more accurate fuel management decisions.
I make the sheet up by starting with an empty tank, then taking pictures of the gauge as I put in measured amounts of liquid.
