Replacing motor mount
Feb 26, 2018
2
Catalina 22 Sunrise Beach, MO
Hi. I’m planning on replacing mount on my 87 C22. The current one was intended for light 2 stroke and my boat has 4 stroke 8hp. Currently raising/lowering nearly impossible for this old man. Going to put new mount with springs intended for heavier 4 stroke.
Will I have to cut fiberglass back of port side on inside to access mount bolts?
Dec 5, 2011
551
Catalina Catalina 22 13632 Phenix City
I think you should be able to access the bolts by crawling behind the dinette table seat under the cockpit, all the way to the back and looking up. I have an 86 model and have been in there but my motor mount is fine and I have no need to get all the way to the bolts.
Sep 30, 2013
3,563
Slim is right, no need to cut anything. You are probably not going to like crawling back there to get at the bolts, though, and crawling out is even worse. A spry young helper can be worth his/her weight in gold. Otherwise, patience and a sense of humor as you try to back out of the "cavern", with all the grace of a turtle trying to climb backwards up a stairwell.
May 23, 2016
1,024
Catalina 22 #12502 BSC
LOL, great visual Gene!
PJ, I've seen several others doing the outboard bracket thing here on the forum, adding some vertical L channels or similar reinforcement inside the transom to give the mount better support (spread the load) and protect the transom integrity, rather than just relying on bolts and fender washers....especially important for a heavier outboard IMO...
Feb 26, 2018
2
Thanks for the idea. I’ll go to the boat today and see if this old overweight frame can fit in there.
I don’t have high hopes. May have to get my skinny neighbor in there.
Likes: greg_m
Sep 14, 2014
1,273
Catalina 22 Pensacola, Florida
Mine are reachable through the port side hatch for lazarette
and PO used a backing board along with the fender washers. Maybe yours is mounted differently. Pix included as part of my nooks and cranny series of shots. PO also used it as place to mount some of the electrical connections, later modified, this is a before picture.
Apr 11, 2017
571
Catalina C22 Solomon's Island, MD
I've been back there many times - it's doable for sure.
That being said, if you're like me, you might wish your arms, elbows and neck were attached differently trying to manipulate those fastenings. Lying on your back, with your hands up around your head, is some help if you can.
Apr 11, 2017
571
I have an 87' as well. If you can see anything after you get the bolts out, I'd be interested in what the composition of the transom is.
Mine seems very solid, but it's easy to worry about water intrusion into plywood back there. I'm no expert, but I'd probably try to use some 4200 on the inside of the bolt holes, and good butyl tape under the backing. Good luck with the project.
AaronD
Aug 10, 2014
728
Catalina 22 9874 Newberg, OR / Olympia, WA
I'm no expert either, but it seems to me that the standard drill / dremel / epoxy / re-drill dance we do for deck hardware (as described by @Maine Sail at http://www.pbase.com/mainecruising/sealing_the_deck) is probably appropriate here. It's actually easier to do the dremel part with the big 3/8" holes in the transom than it is with smaller deck hardware. And of course, butyl tape; see Maine's response to my question at https://forums.sailboatowners.com/i...hardware-with-bed-it-butyl-tape.117172/page-7.
The "vertical L channels" @rpludwig referred to are available pre-drilled in stainless from Catalina Direct; they worked fine for me. Stingy sailor used angle aluminum, which is cheaper, if you don't mind mixing metals with your bolts (perhaps coat the hardware with Tef-gel and isolate with acetal washers?). I also reinforced the interior fiberglass with a board of 1/4" G10, but that's almost certainly unnecessary.
May 23, 2016
1,024
HH...regarding transom composition, when I installed rear scuppers on my '84 I found the transom composition to be fiberglass/plywood/airspace/plywood/fiberglass. Why the airspace (approx. 1/8"), I have no clue, but I did fill it w/4000 and line the hole w/4000 as well b4 installing the scuppers....Without stiffing the airspace, bolts would compress the transom sandwich. On an outboard bracket, I'd use epoxy fill there as AaronD suggests.
Sep 30, 2013
3,563
This is the transom of my '88, at the scuppers. The thick layer of plywood is only about a 4" square in reality, not a real part of the transom.
Apr 11, 2017
571
Thanks for the info and photo regarding the transom layup.
I'm trying to figure out what the darker brown material in the middle is - another layer of fiberglass?
Jul 13, 2015
919
Catalina 22 #2552 2252 Kennewick, WA
As mentioned-- crawl through the port aft opening easy enough once you are in there but take everything with you :)
I cleaned up goodness knows how many legacy holes and added a backer for my 4 stroke Honda 5
