So, I had a clamshell sail cover put on the boat (good decision). The jack lines go through a couple of SS rings and those in turn go to a higher ring and then to a block on the second spreader. 7mm Amsteel.
So, I was doing some work and had the cover pretty far open. When I finished, I tensioned it again but found a twist, maybe four turns, at the top. I couldn't figure it out since nothing had been disconnected. Anyhow, my wife and I untied the jacks and took the twist out and then I again retensioned them, with the same result. Finally, with the twist again all out, my wife told me that the twist occurred when I tensioned it.
So, I can only surmise the lay of the line causes a twist when it is in tension. Very odd. Any thoughts? Any experience? Quirky stuff.
