Assuming that someone sees you -- isn't a good idea
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
This was posted on another forum that I follow: Scuttlebut.
It's visual proof of what problems can ensue by believing that on that clear, wonderful afternoon, you can't be subject to bad things happening.
That's not a dark night, in reduced visibility or some other less ideal situation.
Be safe out there.
Nov 26, 2012
1,654
C&C 40-2 Berkeley
That is not proof that problems can ensue by believing that bad things can't happen on a clear wonderful afternoon.
Sep 30, 2013
3,695
"I wasn't using my cell phone, it's just that I was sitting down and couldn't see over the dash!"
Horrifying.
SFS
Aug 18, 2015
2,094
Currently Boatless Okinawa
As I posted in the other thread, at that range and closing speed I would have immediately sounded 5 short blasts on my horn. Might not have mattered, but visual signals don't work on someone that is not looking for them.
Bosman
Oct 24, 2010
346
Solina 27 Wabamun, Alberta
Wow....did the speed boat operator went to the head for #1? Oh look, there is no one around... The trio fishing were very lucky.
Nov 26, 2012
1,654
C&C 40-2 Berkeley
SF makes a great point. Have a horn on board for this purpose. I have had one or two close calls on the water myself and being able to signal the other boat is key.
SFS
Aug 18, 2015
2,094
Yeah, I learned one day from a similar interaction. Similar situation, though I was under power, but directly under a bridge, with 50 yards of wooden boards on either side of me, so not a lot of room to maneuver. About a 28 foot powerboat screaming up the waterway towards us, bow very high, and clearly ignoring the no wake sign it was passing abreast of 200 yards away. He came off plane in plenty of time, but it was an uncomfortable 10 to 20 seconds watching him get closer very quickly.
I decided that day that two feet away in a closed laz is not close enough to have a horn. It is now out, and within reach, at all times.
Nov 8, 2010
11,386
Two of three where cops. Oops. One says he was traumatized, but some cash will make it better. Interestingly, two of three where not wearing PFDs, on the one that did vest did not inflate.
RussC
Sep 11, 2015
1,734
Merit 22- Oregon lakes
I've seen this in several places, but have yet to hear anything about the rescue. did the guy that hit them assist in the rescue ?
No-one was required to have PFDs on, and it appeared to be a calm day on the river, so most would feel comfortable without actually wearing them. Maybe less comfortable in the future however :yikes: .
8,536
Hunter 30T Cheney, KS
I was thinking along the lines of the thread title a couple weekends ago when I saw a guy way out on the ice, fishing alone. No one around to help if he broke through. Didn't see any lines or anything to help pull himself out. A goner if anything happened.
Kermit
Jul 31, 2010
5,722
It loooked to me like they didn’t have time for a horn.
Tod
Dec 30, 2010
82
Montgomery 17 trailered
I have a feeling that the sort horn of typically carried on a small boat would not have been loud enough to attract the speeding boat's attention. A ship's air horn would probably have been needed, I think, but I doubt the helmsman would have reacted quickly enough anyway.
Likes: Gene Neill
MODERATOR This message has been posted several times under different thread headings. Maybe the posts can be consolidated.
This message brings flash backs.
SG
Feb 11, 2017
1,670
Tod, posted this above. While I'm a proponent of having a horn available -- that power boat wouldn't likely have noticed any horn noise from a handheld horn.
The background noise on most powerboats of that size (or even some much larger ones) that are running at something above a slow pace is a amazingly large.
You have a much better chance with a strong light or strobe at night/dusk.
That doesn't mean that having a horn isn't a good idea. The five blasts is in accordance with the signal for collision alert/emergency coming :^))).
SFS
Aug 18, 2015
2,094
You may be right, but the horn would have been a lot louder than the yelling they were doing, and my main point was that jumping up on the stern locker and waving "taller" was clearly not going to do the job. If the approaching boat had had a lookout, one can reasonably hope that a course change would have happened before the first fisherman looked up and recognized the predicament.
I was really impressed that they all managed to choose the better side of the boat to go off from, though maybe that was really obvious from their angle, rather than the angle of the camera. Late in the video the still pictures of the prop damage to the port side of the fishing boat interior was truly horrifying.
Gunni
Mar 16, 2010
5,937
the pictures of the prop damage to the port side of the fishing boat interior was truly horrifying.
And that was welded plate aluminum. Usually these things don't go so well, or are recorded. Truly miraculous that no one was injured or killed.
