Missing bottom paint
Aug 19, 2005
11
Cal 33 MkII Clinton ,CT
Last summer my Cal33 lost patches of copper bottom paint around all bronze through hulls. Had cleaned all bonding connections before launch and used aluminum prop shaft anodes instead of zinc (which never lasted a season). Aluminums less than half gone by haulout. Why the copper bottom paint loss?
You switched from zinc. My first guess is electrolysis. Aluminum has an electrochemical oxidation potential of -1.706 V and the copper in your paint has a reduction potential of 0.3402 V
so...
2(Al ---> Al+3 + 3e-) +1.706
3(Cu+2 + 2e- --> Cu) +0.3402
2Al + 3Cu+2 ---> 2Al+3 + Cu =2.05V
You have a 2+ volt electrochemical difference between the copper in your paint and the aluminum sacrificial anode.
A zinc anode has an oxidation potential of 0.762 .... almost a volt lower potential.
If you think of voltage as being analogous to pressure..... then the higher the voltage difference, the more pressure two dissimilar metals have to react. It probably was happening with your zinc just at a slower pace. Let me ask you this.... did you have growth problems in the affected area? If not.. I would not worry about it.
Aug 19, 2005
11
Thanks rgranger. Perhaps I'll only use one Al anode this year. Still looking for cause of rapid zinc anode consumption in previous years but that's another topic.
capta
Jun 4, 2009
4,854
Zincs can be affected by a multitude of things that have nothing to do with YOUR boat. An old engine block close to your slip, a steel boat or two on the docks, a leaking shore power connection on one of the dock pedestals. The list is endless.
When I started sailing, there were still boats with copper sheathing on their hulls and if a steel boat came into that marina (or vice versa), everybody's zincs would go ballistic.
It was my understanding that the alloy zincs were for fresh water only. Perhaps that thinking has changed? If you really want to know what is going on with your boat, a surveyor or marine electrician will have a meter for measuring your 'leakage', if any. Call one and get your boat tested.
Gunni
Mar 16, 2010
5,937
Suspicion: Your newly optimized bonding system turned your boat into a more effective partner in marina stray current activity. The aluminum anodes are supposed to last longer which until you get this sorted out is a good thing for your prop and exposed drive.
Capta, if the "alloy zincs" you refer to are the Aluminum and Magnesium anodes, then rest the thinking has changed. Aluminum can be used in fresh, brackish or salt water. Magnesium only in fresh water, zinc only in saltwater. Boatzincs.com has good information on this.
Nov 6, 2017
77
Catalina 30 5611 Stratford, Ct
I had an issue that may be related to yours. When the boat was hauled in 2016 there were no zincs left. The previous year the zincs were worn but still there. I installed a brand new zinc on the feathering prop and one the shaft prior to launching in the spring. I had not changed slips but I did get a new neighbor. As I researched this I found that the likely cause was electrolysis. I checked all the grounds on my boat and could not find any issues so I came to the conclusion that the problem was with either a boat near me with a grounding issue or the problem was the shore power connection. Rather than try to get the marina to test the shore power circuits I decided to check all the boats that were near mine during the season. When I final found my new neighbor’s boat his zincs were also gone. With that I concluded that one of us had a problem. I decided that I would double the shaft zinc to two and install the normal one on the feathering prop. And just to be safe I also installed a galvanic isolator. This year when the boat hauled the zincs were more than 60% left. I just happened to be at the marina when the hauled my neighbor’s boat and there were again no zincs left. My conclusion to all of this is there may be a problem with his boat that is affecting boats around it. I say this with a bit uncertainty as he did move to a slip further away on the other side of the dock However when I looked at the two boats that were next to his last season their zincs were gone or mostly gone. Although the galvanic isolator my be saving my zincs and consequently my expensive prop I really don’t know, but I do know that if there is a shore power problem it will protect my boat. I think it is good insurance. Your problem may just be the way the fitting was prepared before painting. There is a primer that is specifically designed to prime underwater metal parts that also my help you.
If the problem is always around or near a particular boat, then the issue is the boat. The shore power problem is a function of a safe shore based AC circuit. The solution is install a galvanic isolator on your boat to protect your boat from those other boats that have issues. Shore side AC is wired such that the ground (green) and the neutral (white) wires are connected at the service panel. This allows current to pass from one boat to another via the ground as all boats are connected via the ground wire even when the boat's AC circuit breakers are turned off.
A properly wire boat AC system has a main circuit breaker that switches both the hot (black) and neutral wires. Shore based circuit breakers only break the hot wire, leaving the neutral and ground permanently connected.
Hope that is clear.
