M25XPB engine. I noticed the other day that the bracket for the on-engine fuel filter is loose. All of the bolts are tight, but the bracket itself has got about 1/4-1/2" of wobble in it (at bolts #29 on the attached parts diagram). The parts diagram doesn't show any obvious rubber bushings, so I'm not sure if it's supposed to be tight, or loose. I also think I've got a very small fuel leak there, possibly at the hoses; it seems like the added vibration from being loose might cause the tubing to wear faster?
If any of you could check on your M25XPB and see if yours is loose I'd appreciate it.
