The optical illusion only works because there is no perspective. If she was a 3D figure spinning in one direction or the other, you would notice het extended foot or hand getting smaller or larger as it rotated away from you or towards you with each cycle. If your brain sees her from the elevated point of view she appears to rotate clockwise, if you concentrate on seeing her from the perspective of looking up at her she rotates counter clockwise. The real trick is to convince your brain that she is flat and not rotating at all but collapsing in towards a centerline and then expanding out to the opposite side each half cycle
- Will
