Here we go again... AGAIN???
Jun 11, 2004
1,935
Oday 31 Redondo Beach
I still go with 5. Rational- water flows from 1 to the 3 before level raises to 2. Then to 5 which overflows again before water can get to 2.
It looks like the bottom of the exit tube from 3 to 5 is blocked so 5 will never get any water.
Feb 17, 2006
5,274
Even if 7 didn't have a hole in it, 3 would still fill before 7.
The water would fill the bottom of 1 until it got to the level of the pipe that poured into 3 then it would fill 3 until the level of water in 3 got to the pipe that goes to 4. If, as the picture seems to show, there is no outlet to 4 then, the water in 3 would fill to the pipe that goes to 5. However, the end of that pipe appears to be blocked also. If those are accurate representations of the system and not due to sloppy drawing programming then 3 would continue to fill to overflowing. The water in 1 would never rise past that pipe to 3 unless it poured in from the faucet faster than it could escape through the pipe to 3. All the water would flow over the top of three and none would get into any of the other containers. On the other hand, if the apparent blockages were non existent then, 4 would fill to overflowing before water would flow into 5 or anywhere else.
Aug 22, 2017
1,609
Hunter 26.5 West Palm Beach
If you assume the connection between 3 & 4 is open, then 4 fills first. If you assume that the connection is closed, then 3 fills first. If you assume that the spigot is closed, then 1 gets 1 drop & that's it. If you assume that the spigot puts out water faster than the two drains on #1 can dump water, then 1 fills first.
Jim,
You have my vote. As long as the water doesn't flow faster than one drain pipe but slower than two.
