We hauled our boat today for a bottom job. The weight readout on the lift was 16,000 lbs. Someone said that that is an overestimate, because of the angle of the slings, and that 14-14.5K lbs was closer to correct.
The spec for the displacement is only 10,300 lbs. I know we've put a lot of stuff on the boat, but 4,000 lbs? Seems excessive. Or maybe the spec is low, and the travel lift reads high?
What sort of readings do others get? Just curious.
