Just got a feature newsletter from Practical Sailor on fire extinguishers. I confess, I don't check mine often enough. I think I have enough dry chemical units on board. I should label the cockpit bin where that one is kept. Maybe it's not as critical on a diesel, but I don't have a "fire port" with an appropriate "clean agent" extinguisher (i.e. CO2, Halotron, FM-200, FE-241). I just read that a typical chemical extinguisher is corrosive to the engine and hard to remove. You can imagine after doing any service to an inboard.
Are you prepared? Units are charged and free of obstructions? Have enough capacity for a typical fire? An onboard unit only last for 10 seconds of continuous use.
This is something I'm going to assess next time I'm out. I'm not even sure where the nearest extinguisher is on the dock or boatyard.
