That's funny ... Ward didn't you just buy one?Personally I prefer Selden Furlex units.
Barry
Looked at a 1987 boat yesterday which had a Navico auto pilot. Looked a bit bare bones and old yesterday. Pic below.
Should I plan on replacing it even if it works?
The boat also had a Hood Furler with a continuous line. Can this furler be used to reef a jib?
Pic below.
Thanks
View attachment 141485 View attachment 141484
Yes, the double line furler can be used to reef the jib. You just need to tie off the working end of the line once you set your reef. What I mean by that is the line that you pull on to reduce the amount of sail (the working end), tie that off to a cleat. Otherwise, the wind pressure will force the furler to unwind the sail.Can this furler be used to reef a jib?
We cruised for 6 years back in the 90's with a Navico 5000 wheel pilot. Even when tensioned tightly, the belt tended to slip especially in following seas . The common practice work-around was to take an old belt and glue it to the wheel to prevent the pilot's belt from slipping. The cogs on the two belts would mesh. Probably not good for the gearing, but served us well over the years. It's a good strong unit and if you do have a problem you can still find parts at salvage yards.HI Ward. What you have is an Navico WP5000. Its is adjustable for how much slipping you need. The cam on the motor can be adjusted accordingly. Read your manual carefully if you have one. However, if you don't have manual let me know ill send you one in pdf form.
Part of the reason for slipping is to allow you override motor movement to avoid what's in front of you in a hurry. If its locked down you will wind up stripping the motor gears. So make sure its not too firm. Best regards, Stargazer II Capt. Rob
