Depending on how the volt meter is wired, this may or may not work. If the meter wires go straight to the battery, then you may see little or no voltage drop when the glow plugs come on. If the meter is connected further downstream in the wiring harness, then you may see a massive drop.One of the easiest keys to understanding if the glow plugs are functioning when you start your engine has been identified for you. Look at the voltage meter as you start the engine. If you turn the key to on and the voltage meter stays above 12 volts then you have a massive battery bank or the glow plugs (which are a heavy draw against your battery) are not heating.
Not true. Same battery, same system.If the meter wires go straight to the battery, then you may see little or no voltage drop when the glow plugs come on.
Actually, I believe that it is true because of the different resistances of the different wires in different parts of the wiring harness. If you run 20 feet of #10 wire from a battery to a 30 amp load, then measure the voltage at the battery & at the load, you will normally get a higher voltage reading at the battery posts compared to the reading at the load. Please try it if you don't believe me.Not true. Same battery, same system.
I was choosing not to assume that the wiring in the boat had never been altered by a previous owner or previous repair guy.I posted the schematic. The meter is on the panel, energized by the key switch. It droops when you energize the glow plugs.
It doesn't matter where the meter is, the voltage will drop. How much is inconsequential to the discussion and will differ from boat to boat, and on the same boat depending on way more factors than are needed here. If the meter doesn't move at all, then the glow plugs are not operating. It can be that simple.Please try it if you don't believe me.
Wires of various thickness constitute a resistance network. Both Norton's Nodal Analysis & Keirchoff's Current Loop laws show that it does "matter where the meter is".It doesn't matter where the meter is, the voltage will drop. How much is inconsequential to the discussion and will differ from boat to boat, and on the same boat depending on way more factors than are needed here. If the meter doesn't move at all, then the glow plugs are not operating. It can be that simple.
