St Thomas USVI odd hurricane damage to hull
Jun 11, 2004
1,918
Oday 31 Redondo Beach
My brother lives on St. Thomas USVI and said there were numerous boats with damage like this. Apparently the plywood/padding between the hull and the stand blew up or out and the stands went through the hulls.
He said boats in the water generally fared better than boats on the hard.
He was well prepared and lucky and had minimal damage.
Nov 6, 2006
10,208
Boat probably rocked over on the keel allowing the pad enough room to depart the area.. then when the boat rocked back down the stand poked a hole in the hull..
Gunni
Mar 16, 2010
5,937
That's what happens when you make your own jackstands because you don't want to pay for the real deal. A brownell jackstand pad is positively attached by a screw shaft and the pad is fastened to the swivel. All the same, once a boat floats off the stands, you will have a problem. In hurricane land and in the low country you need high ground.
Likes: NYSail
Jun 11, 2004
1,918
I suggested that to my brother and he said the pads were usually / almost always well fastened to the stands. That's why he thought this was unusual. I'm guessing you are correct though.
Jun 21, 2004
3,111
Beneteau 343 Slidell, LA
Kloudie,
Think that you're correct. From the looks of that photo, most of the boats are tilted over like dominoes. If a stand has an old pad on it, like most that I have seen, that rocking motion and ultimate falling of the boat likely caused the pad to part and result in a punctured hull.
Sep 23, 2009
1,477
How firm is the ground there. Looks like soft mud in the picture. How many stands per boat.
Nov 13, 2013
723
Catalina 34 Tacoma
Gunni +1
I would bet the yards insurance would not cover damage like that since that stand is a POS. Anyone that used it would be negligent.
