Solved:The mystery of the PSS shaft seal overflowing vent tube
Dan_Y
Oct 13, 2008
514
Hunter 36 Hampton
We have a PSS dripless shaft seal installed in our h36 and I ran the vent tube up in the engine compartment into an overflow bottle per Mainsail's suggestion. The top of the vent hose is about 14" above the waterline. The overflow bottle would catch water on our h30 due to aggressive use of reverse gear, but this does not typically happen on our h36, maybe just a oz or two. So I was surprised to find the bottle full and overflowing a few times over the last 3years we owned the h36 and I was mystified.
Turns out that when changing the zincs in the water, air begins to collect in the scalloped area where the shaft log exits the hull and bubbles up around the shaft into the PSS bellows. The trapped air in the bellows then pushes water up thru the vent tube into the overflow bottle to escape. No kidding. It works like an old aquarium filter. The scuba air rises thru the vent tube, pushing lots of water ahead of it, easily filling the bottle in the time it take me to change the zincs. The Admiral watched it happening and emptied the bottle when I surfaced for the second zinc. So next time I'll either plug the vent line or let it overflow into a bucket.
Jun 11, 2011
1,243
Hunter 41 Lewes
Good catch Dan. I'll have to look for that the next time the diver is under.
Dec 19, 2006
5,809
Hunter 36 Punta Gorda
I have the bottle high on the venting tube but to be honest have not found much water in the bottle over the last few years and do check it often but will see if a difference next time change zincs.
My bottle is in the cabinet just above the engine in the rear berth next to the water lines going to the shower and check very easy often.
Nick
Rick D
Jun 14, 2008
7,132
Hmmm, sounds like an issue for those of us left-coasters who have monthly bottom cleaning.
Dec 19, 2006
5,809
I think it depends how high the vent tubes are and proper air release and I hardly ever get much water in the bottle maybe 1 or 2 oz in bottle.
My tube goes straight up high.
Nick
Jul 1, 2010
962
Catalina 350 Lake Huron
Neat scuba trick. When our bottle overflows, it's because I've forgotten to check it in a while, and it makes a mess on the floor. I'm always happy when I find it though, because the boat isn't leaking.
Dan_Y
Oct 13, 2008
514
Hunter 36 Hampton
It's interesting Nick doesn't have the same problem because we have almost identical boats and our bottles are at about the same height...his is a few inches higher. Maybe I exhale too much when under the boat...:). The images below show the scalloped area in the hull that collects air where the 1" shaft exits. Note I had the engine mounts adjusted to get the shaft back in the middle of the log opening. In the photo showing the collection bottle, the water level in the PSS vent hose can be seen as the dark band just before the hose drops out of site behind the engine. I remeasured and it's 22" up from that point to the top of the bottle. So I suspect the small diameter hose (1/4 or 3/8') doesn't let the air by from a good exhale under the boat like a larger diameter hose would and pushes the water into the bottle. Next time I'll plug the line at the bottle when cleaning the bottom.
Dan
jviss
Feb 5, 2004
6,745
Tartan 3800 20 Westport, MA
I just got a boat that has a PSS dripless shaft seal, and the "vent" line is connected to a "T" on output side of the raw water pump. Does this make sense?
Feb 14, 2014
7,399
Hunter 430 Waveland, MS
Yes. I did mine that way also.
Most higher RPM shafts are sealed that way.
I like it since I sometimes have to do a Reverse off a silty bottom.
The PSS can suck up silt and is later purged of silt with clear water.
2 years this way. No issues.
Jim...
jviss
Feb 5, 2004
6,745
Thank you! I'm glad to hear that.
Did you get the "T" from PYI? I would be concerned about how brass would hold up, I think bronze is preferred.
By the way, the "T" on mine is just after the raw water pump, if I recal correctly. There's a mess of raw water lines on mine, one of which looks original (yikes!), and I plan on sorting it out soon. I think yours, after the siphon break, is the proper way to go.
7,399
Yes. I called them and talked at length about how to properly vent my new PSS.
I need to correct that picture caption. It was a BRONZE 1" x 1" x 3/8" hose barbed TEE for $45.
This is from PYI manual.
Mine too! The round object in the picture with the "Rabbit Ear" hoses is the engine raw water pump.
Someone was worried about the flow loss from engine cooling. Minor! The tight clearance on the seal carbon face and stationary SS plate is so small, Seal cooling flow does nothing to engine cooling.
No!:badbad::badbad:
Mine is where it should go, BEFORE the breaker. My water flow is left to right on my picture.
Down stream of Siphon break could by-pass the siphon break effects by sucking sea water around it.
However if your sea water pump had new impeller, it should not be a major issue.
Jim...
jviss
Feb 5, 2004
6,745
I'm confused. I always get confused about siphon breaks.
Feb 14, 2014
7,399
Water falling, creates a pull or vacuum, that will continue to flow from a higher elevation source to a lower one.
In this case...
When the engine stops and pumps stops, it is possible for flow from sea, to flow past the pump impeller and continue to flow into a open engine valve via the exhaust riser. Not likely , but possible.
The Siphon breaker has a small valve at top of "hump", that opens when under a slight vacuum for air to enter. Closed when under pump pressure. The input of air "breaks" the siphon and stops it.
______
Since the PSS seal can flow sea water backwards when the engine is down, putting it on the down stream side of the Breaker, would allow the PSS seal to flow[backwards] into the open engine valve, if the elevation of the seal purge line is higher than the engine top.
Putting it in front of the siphon breaker, would let the breaker do its job.;)
Jim...
jviss
Feb 5, 2004
6,745
OK, thanks. I understand the concept, I just have to draw a picture I guess.
That said, I wouldn't be worried about water flowing past the impeller, but I would about water siphoning via the PSS. But, the destination would have to be a lower level that the waterline. I guess the muffler is, but I don't think the riser elbow is. Anyway, it's worth having the siphon break, and mine has it.
Feb 8, 2014
1,300
Columbia 36 Muskegon
And any boat that motors over ten knots has to have positive water pressure to the vent line. Without it the boats forward motion would suck the water out of the shaft log and burn the seal. My commercial boats are plumbed that way, with a direct line from the rw pump to the seal. In fact its the only reason there is an rw pump as the engines have keel coolers, no rw pump needed for engine cooling.
Likes: Rick D
Sep 30, 2016
10
Hunter 36 Westbrook, CT
I know this is an older post but in terms of the overflow from the vent tube, we found this kit to be a great solution.
Hy-Vent Air Vent with Installation Kit Designed to Prevent Overflow of Seawater from a Packless Shaft Seal System on Sailboats and Low-Speed Motor Vessels
https://www.amazon.com/dp/B08W9DZW1S/ref=cm_sw_em_r_mt_dp_G8G5HZTTVK1DM0HA8FZ9
Amazon.com : Hy-Vent Air Vent with Installation Kit Designed to Prevent Overflow of Seawater from a Packless Shaft Seal System on Sailboats and Low-Speed Motor Vessels : Sports & Outdoors
Feb 14, 2014
7,399
That air vent is use by many. Another Brand is Titon. It was recommended by Maine Sail to allow Air to vent out.
  • Once the water normalizes, the float will open, allowing air to freely vent. This is a great product to maintain an air free system and ensures the engine room stays dry in the event of back flow.
No old thread is never that OLD...
Jim...
