Battery Bank: 2 deep cycle Group 29 flooded batteries in parallel to get 24Volts at approximately 120 amp hours.
Goal: To charge the battery bank without plugging in to the grid. The bank will have periods of inactivity so it will have time to charge up and then trickle charge.
So here is the questions for you solar experts: Is it better to charge the batteries separate by doing two 50 watt panels and two charge controllers OR use one big 100 watt panel at 24 volts and 1 charge controller?
Any suggestions on the components to use?
These can and probably will be rigid panels and not flexible panels. Keeping the expense down is probably a good idea too.
How would you do it?
