bilge blower question
Gunni
Mar 16, 2010
5,937
My bilge blower died and I had a new one installed. It is pulling air in from the transom dorade and blowing air into the engine compartment. That seems wrong. There are two passive dorade vents at the companionway. Seems like they should be intakes to a negative pressure engine bay. Wondering how other early 2000's Beneteaus are set up.
Nov 23, 2009
437
Beneteau Oceanis 361 Clipper --
My Beneteau 361 has two "holes" at the transom, port to the opening to the cockpit, where two flexible hoses are connected to take fresh air into the engine compartment. There is another "hole" at the transom, starboard of the opening to the cockpit, at which a plastimo bildge blower is connected (and another flexible hose) that extracts hot air from the engine compartment.
Gunni
Mar 16, 2010
5,937
Ron; I need that mechanic, he fits into small places!
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
My 323 has intake and exhaust "dryer vents" side by side through the transom.
One is intake air, other is exhaust. Blower is on the exhaust side venting the hot air out.
Either your blower is installed backward or wired backward.
Jun 9, 2008
1,847
- -- -Bayfield
If the wires are backwards, in other words, if the negative wire is hooked up to the positive wire and the positive wire is hooked up to the negative wire the blower motor will run in reverse. I'd check that first.
Gunni
Mar 16, 2010
5,937
If the blower is wired up backwards my concern would be that circuit protection is messed up.
Beneteau 323 Annapolis MD
Doug, my B323 has two intake vents, one on either side of the companionway. One exhaust on the stern. Changes from year to year apparently.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
One generally wants to blow cool air into the engine space, and have the air exhaust through another vent. If there's only one air passage and you are either blowing or sucking air, you are not ventilating the engine compartment. You need an in, and an out, and typically, if you're heating up the air, the out need be bigger than the in.
The reason you blow is that you don't want to potentially suck combustible vapors into the electrical motor.
... The reason you blow is that you don't want to potentially suck combustible vapors into the electrical motor.
The reason you DON"T want to blow is that you'd pressurize the engine room to a degree, and the fumes would be blown out every little crack and hole into the living areas.
jviss
Feb 5, 2004
7,090
That's a good point.
Jun 21, 2004
3,104
Beneteau 343 Slidell, LA
My 343 has two small vents adjacent to the companionway and one large vent that terminates under a cowling mounted on the stern.; however, no blower. That's on the project list to install an inline blower in the large ventilation hose that will suck hot air out of the engine room and vent it out the stern cowling. The two vents adjacent to the companionway should be adequate to supply fresh air into the engine compartment.
My 343...however, no blower. ....
NO blower? IIRC, that's like a requirement? Maybe it just does not/never did work? I'd look for it, if you have not already, behind the lazz, toward the vent-out cowling.
Jun 21, 2004
3,104
Ron,
I previously traced the vent hoses. No blower present. The 343 that I chartered many times ,before purchasing mine, didn't have a blower either. Weird??
DougM
Jul 24, 2005
2,242
Hey Ron,
my 323 has the vents on both sides of the companionway, They appear to be purely decorative/dead end.
I thought they were actually night lights for the companionway that never worked when I first got the boat. I never cared if they were and didn't work.
I believe a blower is only a requirement for gas engines. I think Beneteau just uses them to keep the engine area cool; fumes aren't as much of an issue. That's why most of our blowers just come on when the ignition is on rather than needing to be run for a few minutes before starting.
... They appear to be purely decorative/dead end....
I never took the vent covers off, but I always thought the air goes down the hollow between the cockpit mold and the head wall? Maybe not so? That is the only way I see fresh air getting into the engine room.
Gunni
Mar 16, 2010
5,937
The blower creates negative pressure in the enclosed engine bay which is relieved by the intakes. You should have flex-ducting from all dorades into the engine bay. Diesels run best and cleanest with plenty of fresh air, and the boat remains fume-free if those fumes are being expelled out the transom.
