(See post #19)
2003 Catalina 310, Universal M-25XPB
Following routine shutdown after running the engine I get an intermittent Low Oil Pressure light and ticking coming from the engine compartment, I think it is the fuel lift pump.
The low oil pressure light and the ticking occur simultaneously for roughly 10-15 seconds, stops, does it again. This lasts for about 15 minutes or so and goes away. Again, does this with the key out, battery off and following use of the engine.
Any thoughts? Questions?
We are planning for a cruise next week. Should I be worried?
I believe another member had a similar issue. Can't find that thread.
William
William
