Experience with Electromaax External Voltage Regulators
Bob R.
Jun 5, 2004
161
Marlow-Hunter 40 Pasadena, MD
Does anyone have any experience with the performance and durability of Electromaax E-MAAX Basic or E-MAAX PRO external voltage regulators used with their high output alternators? I am in the process of ordering a new Marlow-Hunter 40 through a factory direct purchase and have requested an externally regulated alternator to optimize charging for a battery bank consisting of a 480 amp-hr house bank (four 6-volt Victron AGM batteries) and a Group 27 Victron 12-volt AGM start battery. The alternator will likely be 140 amp. Marlow-Hunter has suggested using an Electromaax alternator and external voltage regulator. The E-MAAX regulators appear to be a relatively new product (they used to use Sterling regulators). They have a remote programming and monitoring panel that appears to have a lot flexibility for custom charge profile programming and temperature probes for both the batteries and alternator. https://www.electromaax.com/technology/emaax/
The cost appears to be more than a Balmer MC-614, but the remote panel may be useful for monitoring and troubleshooting. Has anyone used these voltage regulators?
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
I'm just curious as to what kind of alternator mount and belt you have, with that big a bank and alternator.
Bob R.
Jun 5, 2004
161
This is for a new boat. The engine is a Yanmar 4JH57. The standard alternator is an internally regulated 125 Amp. with a saddle mount. I would be satisfied with a 125 Amp alternator, but would prefer an external voltage regulator to get faster charging from the engine. Marlow-Hunter has offered an Electromaax high output alternator with their E-MAAX external voltage regulator. The 140 A alternator comes with a wide serpentine belt drive.
jviss
Feb 5, 2004
7,089
I would go with the 140A alternator and serpentine belt option, but even that is maybe not enough for a 480AH house bank. If that bank gets down to 50%, it will look like a dead short to the alternator! (Kidding). In bulk mode, you would want to charge at c/3, which would be 160A for you. You would want to make sure your regulator limits the current to what your alternator can handle. I's really a thermal limit. Plus, you want some margin in these calculations.
Bob R.
Jun 5, 2004
161
The advertised programming flexibility and the external control panel of the E-MAAX regulator is what got my attention. The mfr says it will support temperature probes for both the alternator and the batteries to limit current. I'd like some confirmation from users that the controller works as advertised and durability holds up well enough to justify the price.
SG, thanks for the link to Cruisers Forum on problems with Electromaax customer service. There was also a link to Rod Collins project site with a warning about customer service. Not very reassuring.
Mar 20, 2007
500
Catalina 355 Kilmarnock, VA
I'll second (or third, or whatever) the warnings above regarding their customer service - it's abysmal. They actually make a decent product, but you'd better hope you don't have any issues later that require their help or support. I purchased a full package from them (140A alt, serpentine belt kit, and Balmar 614 regulator). The Balmar they sent me was an obviously used unit that had been superseded years earlier by a newer version. It took 6 months of emails, phone calls, etc to have it replaced despite their admission it had been sent mistakenly, and then only after the Better Business Bureau intervened. There were other issues with them as well that I won't even get into. I'd go with an established company with a good track record.
Likes: jviss
Jan 25, 2011
2,437
S2 11.0A Anacortes, WA
I had very good experience with them. I installed a Balmar alternator and determined I needed a larger diameter pulley to slow it down. Balmar didnt have one that would would work so I called E-MAX..Forget who I talked to, but he spent a lot time searching his sources and said he came up with one. He charged me a very nominal fee. Several days later it showed up in the mailbox and it was mailed from 30 miles down the road...Balmar!! I opend it up and the pulley was the right size but had it had a spacer around the hole that was an ontegral part of the pulley. Part of the block the pulley was made from...Immediate belt alignment problems....got out my trusty mic and determined if that spacer was gone, things "should" line up perfectly so I took it to a machine shop and they chucked it up in a lathe and removed the spacer and squared everything up. Cost about 15 bucks. Installed on the alternator and installed on the engine with perfect alignment. Called E-MAX back and related my story with thanks and he stated they have a "working" relationship with Balmar.
Likes: marcham
Jun 17, 2022
236
Hunter 380 Comox BC
Bringing back an old thread ..... I recently installed 2 Electromaax Pro X regulators and worked on a 3rd installation. One was installed a balmar 100A and the other on a Delco 80A alternator.
Overall it's very very good product at a very competitive price. Support via email and phone was excellent, even with the owner chiming in to my support email enquiry within a few hrs ensuring I was being looked after.
First install took about 6 hrs, second about 2 hrs. The fact that remote support is available in case you have issues with the config is really great. The product has a lot of configuration options (and excellent engine load / battery charging management) options, thus the complex UI and large number of settings. Read the manual 2-3 times (both the quick install guide and the full manual) and you should be OK if you understand how alternators work and how batteries are charged. RPM input from the alternator is optional but opens up additional config options.
I can't explain why my alternator is producing less heat (20-30 deg C cooler) and provides about 30% more output than my old Balmar, and plays much nicer with my lithium battery (it has never forced a BMS kick off during charging, which happened from time to time with my Balmar regulator due to poor voltage regulation).
The ability to easily send the information to your instruments via NMEA 2000 (Pro X) avoids having to use the app while under way.
Lightyears beyond Balmar in terms of capability and far better value than WS500.
All the units we installed came with alternator temp sensor, alternator current shunt, battery current shunt and battery temp sensor.
11,709
The main guy , the good guy, Left Emaax a year and a half ago and joined ARCO. Balmar was bought by Dometic and customer service is now pretty much non-existent. Everyone I worked with at Balmar are now gone including Chris Witzgal..... ARCO is really ramping up and producing excellent equipment. The ARCO Zues reg is amazing as are their new alts..
