I am having problems with the Harken roller furling wrap stop on my 1984 H31 . When I furl the jib the wrap stop seems to be catching and causes the jib halyard to want to wrap around the foil. I have to keep easing and pulling on the furling line in order to furl the jib. My sail is a bit shorter than a full size jib so I use a short wire pennant to make up the shortage. The pennant was at the top but I tried it at the bottom with no difference. I am thinking that the problem is due to the fact that the halyard seems to run parallel to the foil from the wrap stop to the mast sheave rather than at an angle which would prevent the wrap stop from turning. Has anyone else had this problem and if so, how did you fix it? Thanks for any input. Reg
