transom mount, in hull, thru-hull...?
May 23, 2016
1,024
Catalina 22 #12502 BSC
old discussion, but I need a refresher..
going to pull the trigger on a depthfinder/fishfinder/chartplotter today, WM has a one day sale going on Lowrance, been eyeing the Hook 5 which seems adequate for my river and coastal use, $189 after sale and a gift card I've been sitting on for some time...any negatives on that unit?
so all that said, we all hate drilling holes in boats, have any of you guys used transom mounted transducers? I know many have gone with in-hull in toilet wax or epoxy, but that's another $100 bucks or so IIRC...
not considering thru-hull....
thoughts?
Likes: BlowMeAway
Jul 14, 2015
840
Catalina 30 Stillhouse Hollow Marina
This is what I did with my 30 using the transducer that was designed for transom mount....You do not need to spend another $100. Use the one that comes with the unit and glue to hull with clear silicone. No need to use epoxy. Completely encase it. The key is no air bubbles. Ideal location is in front of keel, but I have mine about 2 feet behind keel. It works perfectly. Every once in awhile, because I am behind keel, I will get some turbulence that loses signal for up to 15 seconds or so.
Jul 7, 2004
8,496
Hunter 30T Cheney, KS
I mounted mine on my Mac26S to the transom. Never had good luck with wax or epoxy on the hull. Just my experience. Mine was mounted so it was only in the water when I had weight in the cockpit. It had a water temp sensor that only worked submerged too.
Jul 14, 2015
840
Isn't yours a water ballast boat? If so you cannot shoot thru the hull.
Jul 7, 2004
8,496
Cannot shoot through foam or any double hull.
Right. Just single thickness 'glass in both areas. It has worked for others. I just never had luck with it so I mounted in back . Only failed when I heeled over on a starboard tack and it was out of the water.
Mar 26, 2011
3,732
Corsair F-24 MK I Deale, MD
Through hull, just in front of the keel. There is no good reason for a comrpomise installation.
I've had transom and in-hull, and they just don't work as well. If is is bumpy or you are moving fast, they fail. Just do it right.
Fitting a through hull is not that big of a deal. Grind the inside smooth, epoxy on a backing plate, drill through both, and seal according to the instructions. If it is a cored hull, seal the core well by removing some core and replacing it with either solid glass or thickened epoxy.
Sep 14, 2014
1,280
Catalina 22 Pensacola, Florida
In hull, just between the forward and aft storage compartments in the v berth, take a small ball of toilet wax and squish the transducer into in and squash onto the hull inside. Firmly squash both and in and out in 5 minutes, only time consuming is laying the connector cable around to depth finder. Best route is starboard side down the settee compartment bottom.
May 23, 2016
1,024
I'll go w/Jacktar's method for starters, reversible if it doesn't pan out...did it once on a powerboat, worked out fine...
-na -NA Anywhere USA
As stated the keys for adding to the inside hull is no foam or wood in the hull, sand off gel coat and clean with alcohol or acetone, add your filler to put a transducer in insuring no air bubbles. Believe it or not, plumbers putty works and takes several hours to dry. Did not think it worked but several years ago I did one that way and still works today for a friend Kermit.
Sep 30, 2013
3,596
My boat came with a transom-mount transducer, mounted in toilet wax. You could tell it had been there for quite some time, and was working fine. But after a year or so in the Florida sun (the boat came from north Georgia), I guess it got really hot and the wax softened up and the transducer kinda fell over. No biggie, I cleaned up all the wax and re-mounted it the same way, using plumber's putty instead of wax. Works great, with no slowly-spreading ugly waxy residue.
May 23, 2016
1,024
Good, that's 2 for plumber's putty, I don't like kneeding toilet wax (and hot here too), and I don't allow silicone on the boat! Plumber's putty wins...thx for the replys on this as usual...!
Ron
Jul 7, 2004
8,496
+1 on plumbers putty vs wax in hot climates. When I put in my heated tile floor in our bathroom, the instructions with the heating element said to give the toilet some clearance because it can melt the wax!
May 23, 2016
1,024
assuming the unit is mounted outside on cockpit bulkhead, port or stbd where I usually see 'em, how did you guys deal with (concealing) the wiring inside the cabin? Bulkhead is solid there except the extreme outboard edge, 3-4", thoughts? Really have trouble dealing with exposed wires/cables.....other than building a chart rack over them (2 cables - one for pwr, one for transducer are exposed), or hanging dirty laundry there I'm stumped...
3,596
Are you absolutely sure? That bulkhead is almost entirely hollow on my boat.
Nov 30, 2015
1,343
Thanks @rpludwig for starting this subject up again. I too purchased a Lowrance Hook7 on sale a few months ago from Gander Mountain during a close-out. The instructions clearly state that the transom mount transducer can be mounted as a shoot-through hull sounder. I've selected a spot under the starboard settee for mounting against the hull on my H30. Unfortunately the transducer cable is a bit short to place where I really wanted it in front of the keel. My chosen spot puts the transducer behind the keel and off to the starboard side a bit. The dead rise angle is a bit more than 10 degrees, but I think it will suffice, I don't see anyway for the transducer to be mounted parallel to waterline.
I like the plumbers putty idea. I think I'll try that instead of using the recommended epoxy. If it works for Crazy Dave and Kermit that's good enough for me.
This is what came with the Hook 7 package, and I've fashioned a swing arm to attach the unit inside the companionway. That swing arm concept was presented in another thread a few months ago and I really liked that idea. Thanks all for any additional thoughts or concerns that I may have overlooked.
May 23, 2016
1,024
Gene...yea, it's solid there, mine's an 84, your's an 86+ IIRC, perhaps the difference....I'm puzzled... (and not fond of the swing arm approach) will try & post a pic of that area tmrro.
((hey btw, you ever get that Corian job done for the Admiral???))
BMA...you need a shorter boat! LOL.....your carton contents are similar/same to the Hook5....on the C22, plenty of cable to reach from under the v-berth to winch area with plenty to spare...tducer will mount in bow parallel (or perpendicular pending your viewpoint) to waterline with no problem. That said, struggling with where/how to hide the cables inside the cabin (assuming cockpit bulkhead mount), nothing against swing arms, but not my first choice, esp. in foul weather situations where we need to button things up....from a few past experiences, that's where we must have accurate depth info trying to get to safe harbor/anchorage in a big sudden blow....
Likes: BlowMeAway
Sep 30, 2013
3,596
Haven't even started it yet. We both want to visit a showroom somewhere and see the available colors/patterns in person. Haven't found anywhere nearby yet, and there are a million other things going on ... you know how it is.
Aug 31, 2011
243
Catalina C-22 9485 Lake Rathbun, IA
I have the Hook 5 with the standard transducer that comes with it. I mounted the transducer under the forward V-berth using a silicone gel and then worked the transducer onto it to void out any bubbles. Works great !! Depth is accurate (checked with a lead-line) and scans look great also. Wonderful clarity. The chart plotter is cool, allowing me to mark spots in the channel with low water. The cost on these is great for all of the benefits and features.
