As a follow up to my long winded marathon battery failure post, I am in the process of planning my re-wire. So, here is my question: I decided about six years ago that it would be a good idea to keep my big house bank from deteriorating by adding a second bank of a small group 24 deep cycle battery. I keep the boat plugged in at the dock and run a refrigerator and freezer 24/7. I mad a judgement that this constant load and charge couldn't be good for the big house bank and so for the purpose of running the refrig at the dock, I would use the small "sacrificial" group 24. I combined the banks when motoring and cruising.
After some years of that, I was advised by a friend who ran big UPS systems for industrial purposes that that wasn't going to help my big bank. He said industry runs big systems and the worst thing you can do is simply leave batteries idle. Thereafter, I just left everything combined as one big bank. However, I recently ran into a few boaters who did the same as I with the same rationale. So, now I am in a quandary about removing that small battery or leaving it and isolating the big bank while in the slip.
So, do you think:
A) your original thought to use a small battery to save the big bank was a brilliant piece of deductive reasoning and you should continue to use it, or
B) I have never heard such an inane, flawed piece of amateur logic and you should remove that disgusting apparatus, or
C) I don't know, but you should listen to your experienced friend, or
D) this is what the real facts are (insert facts).
So, do you think:
