Background (1994 Hunter 40.5):
I am considering adding capacity to my house bank. Right now I have two 6V golf cart batteries located in my port aft lazarette. I do not have room for another set of batteries in my port locker and it would add to much weight to the stern anyway. I have added a 5KW generator to my Stbd lazarette. With that extra weight now in the stern, I have temporarily had to add about 200 lbs of ballast in the bow below the V-berth to keep her on her lines but I don't like carrying around dead weight.
Right now I have a 40 gal water tank just below the generator that I do not fill except if we are going on an extended cruise. I keep the 20 gal bow water tank full as ballast and just use the port and stbd (20 gal each) belly tanks for routine water needs. I think I've done all I can with easily adjustable weight that I can. If I ever race, I can empty all the water out if necessary to lighten the load but then I'll be squatting a little in the stern.
Now to the questions:
I don't like carrying around dead weight. Its about 40 feet from the bow to where the current battery bank is located in the stern. If I put batteries in the bow below the V-birth:
1. Do I have to use AGMs because of the ventilation (or lack thereof in that location)
2. I would assume I need a minimum of 2/0 AGM tinned wire from the fwd bank to the House Bank but is that even big enough?
3. Will this location and wire run generate a problem with charging/discharging the batteries equally (I would use new batteries for all 4)? I have a Sterling smart charger, and a solar panel with a smart regulator to keep the batteries topped off when on my mooring ball. Both brands/models recommend by Mainesail.
4. If I use AGMs for the house bank, and my start battery is a flooded cell lead acid battery that has a BlueSea ACR as its charge source, do I need to change the start battery to an AGM?
5. Any other advice.
Thanks in advance for the sage advice. I really rely on the collective wisdom of this board and especially the advice from Mainesail.
