Help me win more races
May 27, 2014
31
Hunter 28 High Cliff State Park, WI
I competed in my first race this past weekend with Arcadia, my 1991 Hunter 28. It was a 26 mile race with strong winds to port (so a beam reach). Averaged 6.7 kts, but the winners were closer to 7. I experienced a lot of turning up, strong heel and weather helm but i didn't want to reef because I thought I'd lose speed. If I had reefed my main, would I have actually increased my speed and improved my balance?
May 25, 2012
4,338
possibly, there are too many variables that only you would know, but sure, there are times that reduced sail is faster:)
Gunni
Mar 16, 2010
5,937
Yes. That's not even a racing question. Your boat sails fastest when on her feet, not pushing her hip through the water.
Likes: jon hansen
You are only say .5 knot under hull speed. So that's not terrible. Whether to reef or not is about what happens in the lulls not the gusts. If you are rounding up in the gusts but are otherwise dealing with the lulls than you probably shouldn't reef. You need to react to the gusts to recover more quickly from the round up. BTW, the round ups help a boat get to weather a bit more. On a reach with wind you should have hull speed almost all the time - 7.1 for you. I agree with Gunni that usually sailing flat is fast and I do think dragging your rudder isn't fast. So, trim the sails for wind and stick with the full main if the roundups are the exception. And don't forget to tell those in the cockpit with you to get out on the rail.
Likes: kiteflyer
Mar 13, 2011
175
Islander Freeport 41 Longmont
So having sailed a Hunter 28 here are a couple of pointers that may help.
Tune the rig to make sure you have good balance port/starboard as well as fore/aft. This helps a lot. I had about 6" of rake in my mast and when properly balanced I had a balanced helm (ie: no weather or lee helm). Adjust your jib cars to allow the jib to fly properly. Be careful to not overtighten the sheets , once you have everything flying well, loosen just a little and she will move better.
28's are flat bottomed up front but very beamy. They sail best about about 10-15^ of heel, too much over 20^ and you start dragging rudders and spilling wind.
One final note, from the best racer I ever had the pleasure of meeting, Gary Jobson, Go through your boat and remove anything not essential to the race. The admiral's condo on the water generally does not make a good race boat, too many fluffy pillows, wall decorations, pots and pans, as well as personal items. Get rid of it all. If you don't use it during a race take it off. Otherwise, enjoy the racing, learn as much as possible and most importantly enjoy the beer at the end.
Fair Winds,
Likes: kiteflyer
May 27, 2014
31
Good to know that I was close to hull speed . My 15 Year old son weighs 115 lbs and he was putting all of his weight into the wheel just keep it pointed down wind. I had the main sheeted with the end of the boom out just past the starboard rail when rounding up and I'd bring it in after. Also had the jib pretty tight - maybe too much but the telltales were flying great. Thanks for your reply!
May 27, 2014
31
I've got maybe 4" of rake so I'll tighten my spreaders a bit. Remind me if you would on the proper positioning of the jib cars? And I did have the jib and main both pretty tight. What about the traveler? I kept that mainly to center throughout, but maybe I should have adjusted that too. And I could've used an extra crewman for the rail. Beer afterward was the best!
Nov 8, 2010
11,386
A fully powered-up beam reach race is what skiers used to call a wax-race. No tactics, just go as fast as possible in a straight line.
More twist in the sail will help keep the boat flat and the center of effort low. Move jib leads back. Ease vang and sheet while playing the traveler. Also, if you can, clip your headsail sheets the toerail. This will really open up the sail.
In a race like this, boat might not finish in PHRF order (by their numerical ranking), but you likely will see some longer but slower rated boats crush this race on handicap.
May 25, 2012
4,338
yeah baby, jackdaw is right, that's my sweet spot. if the race is all reaching you can't beat me under phrf :)
love phrf :)
Oct 29, 2005
2,366
have you tried sponsoring the race? RO may give you a good phrf to make a difference ;)
