You'd need a wiring diagram and written instructions for other crew to understand. See post 20 and/or PM me.Like I said, I learned the hard way!...4) Okay, tear this up, and tell me why my setup otherwise is not a good one. Many thanks.
Mr. Murphy says that when you have to abandon your start battery and use the house battery, it will not be at the best of times. Trying to find the tools, access the cables and monkey with them while drifting up on a lee shore..... Much easier, faster, and safer to flip a couple of switches.Shore charger wired to batts. I don't understand why you want an off switch on your starter battery. Why not just wire the starter to the battery side of a switch and leave the switch open? If that battery dies, you can just move the cable to the load side to make use of the house batteries.
Generally, it is better to have one big house battery and a separate smaller start/reserve battery. Why one big house battery and not two? The simple mostly correct explanation is that battery life is in part a function of state of charge and how deep and how often the battery is deeply discharged. The key factor is the percent of discharge. If you have a 100 amphour battery and draw 50 ah out of it you have reached a 50% SOC. however, if you have 2 100 AH batteries in parallel and draw 50 ah out of the bank, the bank will at a 75% SOC. The lower discharge percentage is better for the battery. (Now this is pretty close, there is this Peukert formula that is much more accurate, but this captures the essence.)2) I have three batteries, two house and one engine, and separate charging to each. There is obviously a problem with House battery charging, in that the charger(s) can cross-charge if both House batteries are switched on while charging at dock. Any cross-charging via engine-alternator charging, with engine running, is not considered significant, as that time is minimal.
Sorry for beating another dead horseSwitches allow each bank to be isolated and combined as necessary.
I get it, MS. What I do NOT get is why someone would go to the expense of installing three switches including the DCP when one would do the same thing. IIRC, you have mentioned many times how more connections create more possible points of failure.Stu you really should have read what Dave wrote before jumping on his post about the DCP. What he described is a great way of installing a DCP switch.
Why is turning two switches easier than turning ONE?!?As the saying goes, an ounce of prevention is worth a pound of cure. It is much easier to simply turn 2 switches to isolate the start battery and run everything (starter included) off of the house battery, or vice-versa.
Matters of opinions here. If you do not want to switch a live battery to bridge with a dead one, why would you parallel batteries where, when one crashes, it can take the bridged ones right down with it? Everyone has an opinion of their own. See Stu's post 23.... Generally, it is better to have one big house battery and a separate smaller start/reserve battery... Why one big house battery and not two? ...
A battery in a paralleled bank can crash the whole bank in the case of a sudden catastrophic failure. No question there. But those instances are pretty rare. Batteries die from old age and abuse, especially deep discharges and long periods of time in a partial state of charge.Matters of opinions here. If you do not want to switch a live battery to bridge with a dead one, why would you parallel batteries where, when one crashes, it can take the bridged ones right down with it? Everyone has an opinion of their own. See Stu's post 23.
Let's keep this within the context of the OP who already has two bussed ON/OFF switches plus a third negative switch.. Re-purposing the Beneteau negative switch (which is not ABYC compliant), is the easiest approach to achieve cross over and isolation.. I am not a big fan of the cheap battery switches used by Beneteau & Jenneau & I've seen a few physically melted, and some with over 1V of drop under load, so I generally replace them with Blue Sea switches when ever a customer has large loads eg: inverter or bow thruster.I get it, MS. What I do NOT get is why someone would go to the expense of installing three switches including the DCP when one would do the same thing. IIRC, you have mentioned many times how more connections create more possible points of failure.
There is no one single switch solution for every application. This boat does not and never had a 1/2/B....I also agree with this sentiment: why have the switches when one will suffice IF THE DCP didn't exist?
You and I have spend decades helping folks out in trying to understand their electrical systems. We have offered the single 1-2-B scenario and the two switch version.
99.9% of the time = DCP to ON (does not get any simpler than that and it is the only switch visible to occupants)Wow, now a three switch version? I ain't gettin' any younger, but I have wiring diagrams for everything on my boat. Why? So I can remember. This configuration makes my head spin. I'd need a bloody checklist just to get the boat started and the stereo turned on.
If the 1/2/B switch was really simple, it would not need an entire thread....Sorry, cranky pants day, but it seems simplicity is hard to explain to some folks.
Stu don't become narrow minded about what works or can work. Look at the diagram and run through all the scenarios and you'll see that diagram is ticking all the boxes including simplicity and full isolation including charge sources.. The DCP is only a poor choice if you install it as a stand alone because you loose the ability to isolate a failed bank. Even then the vast majority of the time it works. It is the 0.1% we are protecting for with the addition of to bank isolation switches. I believe isolation, including charge sources, to be a critical design for cruisers and this is all touched on in the 1/2/B thread and a 1/2/B also requiress an additional battery compartment switch if you desire true isolation including the charge sources....OK, explain the advantages of this arrangement. Please. 'Cuz I just ain't gettin' it. One employs a DCP switch that you have many times said is better for powerboats frequently starting and stopping so as not to lose their electronics but not so good for simple recreational sailboats. Now we employ that DCP and add two more switches. HMM, I'm simply agog!![]()
Umm the OP already has TWO switches. Re-purposing the neg switch, which is not ABYC compliant anyway, is often the easiest fix for the Bene factory wiring. You now have a three ON-OFF switch system, which is a great system.Why is turning two switches easier than turning ONE?!?
I'm all ears on this one.![]()
Well, you probably have the always on radio on the dead battery? IIRC, removing the battery cables is suggested- or did you mean you did that, not just the switches off? That is a long time to expect the batteries to be stored. Face it, one battery dead does not mean the entire wiring system is a rats nest. If one survived, that should mean the other may have been a bit defective. If anything, swap the cables on the battery switches to make the front battery to start battery....I thought to be the starting battery would be essentially dead (10 volts) while the other maintained 12.75 volts.
...someone can clarify the reasoning of the negative switch to begin with? ..QUOTE]
There isn't any (logical) reasoning.
This is done all the time, world wide and a recommended practice by every battery manufacturer. Folks only get into trouble when they ignore care of their batteries and push them too far health wise.1) Within the many discussions above, I'm still wondering what people are thinking about having multiple batteries on a single charge circuit. Even if exactly the same age, size, etc.,
If you wire them incorrectly they can and will become out of balance. When wired correctly I see little difference in tested capacity between batteries that have been contiguously wired as a single large bank. I have physically tested, for actual Ah capacity, more lead acid batteries than anyone I know of in the marine field. There are only about 3-5 of us actually doing it but everyone should be... I have two 20 hour test stations running nearly continually and am adding a third shortly.I think that within a year, those batteries will start diverging in quality, and the charger will only be supplying some sort of average or amplified charge. Is it felt that this is insignificant? Thank you.
There are plenty of really good deep cycle 12V batteries in AGM & GEL and in golf cart and better flooded batteries. The Trojan T1275 a very decent 12V deep cycle battery. Any 12V flooded battery that is G 24, 27 or 31 is not really "deep cycle" compared to a golf car level battery or better but for coast cruising can certainly work.. Course there is never any need for using 12V batteries for a house bank when 6V golf car batteries are less expensive and extremely robust....2) I haven't heard whether or not there are, with new technology, any really good 12v deep cycle batteries.
3) I've decided that I'm going to do my battery wiring as shown in the attached jpeg, talk about KISS. Once again, I realize, is that if both House batteries are switched on, while plugged in at dock, there can be a cross-charge, but signage at my battery switches has so far prevented that.
You can keep it simple with your 1-2-Both switch. First step ... get immersed in the discussion on MaineSails site here in SBO. Under "Featured Contributors" go to "Musings with Maine Sail" and go to the thread titled "1/Both/2/Off Switches ...." and read as much of it as you can stand. There is about 12 pages of discussion. You may want to have 2 identical batteries, wired in parallel, to use for your house bank and a separate, smaller battery for your "reserve" bank. You will have greater capacity and longer battery life if you increase from 1 battery to 2 batteries for your house bank. This would be a typical set-up for a coastal cruising, weekender type boat such as yours. This thread is pretty much focused on the system that would be used with the switch that you have, so there really is no need for you to look for any great modifications. There are various ways to configure a battery system, and we all have our preferences. As with anything, there are always pros and cons to every system. Yes, your house bank is suitable for starting your engine. The reserve is simply reserve. Your switch can keep the 2 banks isolated. You can charge both banks without difficulty. You do not have a real need to have a separate "start" battery. Some people prefer to have a separate start battery, but you should really read up on the reasons for it and the system modifications before you feel any compelling reason to do so.All this discussion about additional switches is getting me a bit confused. When you switch to 1 or 2, aren't you effectively isolating, or do you have to open the negative side to truly isolate?
In my intended plan, am I running afoul of the ideas in the general discussion here? (Apologies in advance if this question is elemental and off-topic to the thread. No doubt I can find answers in the archives.)
