Outhaul purchase
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
So, I finally decided to increase the purchase on my 192's outhaul. I decided the easiest thing to do is add a cascade with 1 block. I still needed to drill and rivet an eye strap, but that's not too much modification. Even though it's only 2:1 purchase, I think it will be easier to pull on outhaul all the way in a breeze, without it loosening up as I try to cleat to the horn cleat. I'll add an adhesive ruler to it later, so I can look like a legit racer... :cool::yeah::biggrin:
It was breezy and gusty as heck yesterday, so I'm glad I finished the install. Went out with full outhaul, laid the toe rail in a few times while sitting on the cockpit coaming, then decided I ought to reef. STILL washed the toe rail a few times. And had quite the fastest DDW run I've had in a long time.
Mar 26, 2011
4,008
Corsair F-24 MK I Deale, MD
Neat.
For the record, eye straps are many times stronger if installed in-line with the rope, with a loop instead of a stopper knot. Last weekend I watched a guy replace one that was installed sideways like that. It bent sideways and levered the rivets out (topping lift, Cal 25).
I wouldn't worry about it on this boat, for a hand-tightened line. Just something to remember.
Nov 9, 2012
2,500
Neat.
Dangit, that's what I thought! I was going to ask for opinions, but didn't have time to wait for an answer. Yeah, I looked at the orientation of the leech reefing line eye strap, and I guess if I had it tied with a bowline, then it would be pulling in-line while reefed. It was hot on Sunday, and I guess I wasn't thinking too straight, because I thought I might put it in-line, and then didn't wind up doing that. Well, heck, if it pulls out someday or bends, I've got enough room to move it.
Hey, Thinwater, didja see the PM I sent you about mildew treatment?
Mar 28, 2016
19
O'Day 222 Key Largo
I rigged my 222 outhaul the same way, plus I used a block and soft shackle at the clew for less friction. Also mounted a clam cleat to use instead of the horn cleat. Works good but I rarely adjust it anyway!
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
Thanks to both for putting in these success stories, particularly with pictures! A decade from now, some fellow will be wondering how to do this and you've helped him out. As a follow-up on Thinwater's comment about eye straps, the molded line along your boom is there to mark the center of the boom, and to make it easier to drill without necessarily pinging with a center-punch.
Nov 9, 2012
2,500
Jpniewski, that's cool! I see with another eye strap and single block on the clew, I could increase the purchase on mine. We'll see, but I doubt I'll need more purchase.
Nov 8, 2010
11,386
Neat.
It's stronger for sure, but still can be leveraged out. But for your boat probably either way is fine as TW notes. For a great low cost solution for that application, use a terminal eye strap and a d-ring.
11,386
Well 2:1 is the biggest bang-for-the-buck single block addition, it cuts the original load in half! Minus friction of course. A simple and easy way to almost cut it in half again is to just loop the outhaul line thru the clew and and back to a hard point at the end of the boom.
