#1 The Kiwi prop moves the blade centers aft, about 4.5" aft of the front of the hub, when compared to a fixed prop. The Campbell Sailor fixed prop places the blades about 1" aft of the front of the hub, most feathering and folding props move the blade centers aft.
#2 The Universal engines are pretty notorious for having a rough spot in the RPM range which could start the shaft whip.. With the blade centers so far aft of the strut it can be hard to stop once started while maintaining the same/similar RPM.
#3 You also have a soft brass shaft. There is a large difference in resistance to shaft whip with an Aqualoy 22 shaft vs. brass. For example the torsional yield strength of a 1" Aqualoy 22 shaft is approx 87,000 and a brass shaft is approx 15,000 to 22,500 depending upon metallurgy.
#4 The C-36 has a rather long shaft and as such is very sensitive to shaft whip. IMHO that boat should have NEVER had a brass shaft. Converting to an AQ22 shaft was one of the first things I did when we bought our Catalina 36. An AQ22 shaft may not cure the issue but it can certainly help minimize the propensity for jump rope/shaft whip..
Combine these four alone, not even including anode placement, which should be about one thumb length from the strut, and you can induce shaft whip, especially on long shafts..
Questions:
*Was the prop correctly "lap-fit" to the shaft?
*Are you sure the prop is not getting key bound and that it was correctly installed on the taper?
*Does the cutlass (Cutless® if made by Johnson-Duramax) have any play?
*What is the alignment?
*Has fit and facing of the coupling been verified?
*When the shaft was "removed" was a new coupling installed and fitted and faced or did they re-use the old coupling?
Many thanks Maine. In reply to your questions -
*No, prop was not lap fit. Had to look up how to do that. Next time I change/remove prop it will be done.
* When I installed Kiwi I did check fit of prop w/o key first then installed with key to same place on shaft.
* Cutlass had no play - I installed new one
* Total re-alignment was done by yard along with new motor mounts. I can only assume it was done correctly along with checking fit & facing of the old coupling. Given the fact that I have no wobble below 1600 or above 2200 rpm with the Kiwi, and no wobble at any rpm with the fixed blade prop I would say coupling and alignment were pretty good, no?
Given all the info though I think my next move is definitely to invest in AQ22 shaft. Additionally, I will move the anode closer to strut as I estimate I am at least an inch away now.
Another question Main, Given my boat, what feathering and or folding prop might work? I am guessing one where the blade centers are not that far aft?
I wish I could make these moves one at a time but I am inclined to purchase the new shaft and prop at the same time, follow above advise, and get on with sailing. As it stands now I think I will just have to stay out of the 1600-2200 rpm range until haul out in the Fall when I can begin making changes.
Thanks.
