Transom Shower 311 Model
Apr 25, 2017
8
Beneteau 311 Grapevine Texas
I have a 311, and I don,t see a place on the transom to select hot or cold water for the shower. All I have is an on/off button on the top of the shower head. Am I missing something or is that the design for the 2001 model of this boat.
May 24, 2004
7,228
CC 30 South Florida
Sounds like a wash down hose and not a shower. If you have a water heater on board it is very easy to convert the shower to hot and cold and believe me when I say it will be well worth it. Install a mixing valve and run a tap to a hot water line. A complete kit like the one below can be found at a chandlery for around $50-$60.
140
Beneteau 311 Seattle, WA
I have a 2000 311 and mine is cold only. A mixing valve as suggested above seems like a nice addition, although that box would require cutting a big hole in the transom compared to the small one that is there now.
I have considered lengthening the hose that mine has so that I could use it to washdown the entire cockpit as well. Had looked into a rolling hose or something similar instead of the standard hose inside now.
Beneteau 323 Annapolis MD
You should be able to use what is on a B323- two holes, maybe 3 or 3.5 inches. Spout comes out of one, the on-off/hot cold handle is in the other.
Likes: stevemitchell
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
Can't you put the current line on a remove mixing valve, then plumb it? If the valve was inside a cockpit locker it could work -- or put on another location. It's not perfect, but you'd not be cutting holes in the cockpit walls.
