when I flip on the DC switch to run the bilge she makes a noise like she's running and I felt a slight vibration on the electric pump motor but I do not notice the minuscule amount of water in the bilge ever emptying out. How do to further troubleshoot and fix it? I had a couple shops doing various work on the boat over the last year, including replacing the wiring to the pump. All had said it works. I don't recall inspecting it closely myself after work was done in the past. Is there a minimum level she doesn't pump to a dry state or is the angle of the discharge hose that dribbles water back in the bilge?
