Hunter 27-3 Faucet Heads
Oct 19, 2006
337
Hunter 27-3 Brownsville, VT/Mystic, CT
As we continue to get our new-to-us 2007 H27-3 ready for launch, I seem to have a broken transom shower head. But here's the question:
This faucet, like the head faucet, is a shower head. However, the transom head has a lever to turn flow off, while the head lever turns the flow on. That seems backwards to me.
If you're showering in the head -- a highly unlikely scenario for us, I might add -- you wouldn't want to have to reach up to turn it on; you'd want constant flow, no? And for the more likely use -- washing hands, say -- again, you want flow when you turn on the spigot, not have to push the lever with soapy hands.
Conversely, on the transom, I'd have the shower head in my hand and it would make more sense to me to use the flow control lever to initiate flow at the point.
Thoughts? What is the configuration for owners' boats in this line?
May 24, 2004
7,235
CC 30 South Florida
I gather your interior shower head has a push button on/off valve in the handle and your transom shower does not. If this is correct I agree that the present configuration does not make the best sense. See if you can switch them out and if not at least replace the broken down transom shower head with one that has a push bottom valve in the handle.
Oct 19, 2006
337
They both have push levers. On the transom, it's push to turn off. In the head, it's push to turn on.
May 24, 2004
7,235
CC 30 South Florida
Well it seems it is what it is. Whether by design or manufacturing defect you have ended up with two different working valves. I would just replace the stern shower head to a push to turn ON.
Jun 3, 2010
177
Hunter 27-3 Erie
Sorry Kevin, can't help you out with this question. Both of those shower heads were broken (unknown to us) when we bought our boat so both have been replaced. The new ones are both push to turn on.
Oct 19, 2006
337
At this point, I'm just going to replace the transom shower head through the vendor on this site. Thanks for the $0.02 worth!
Beneteau 323 Annapolis MD
...you'd want constant flow, no? ...?
No, you might think so, but you're not at home, Toto. If you let the water run, you'll empty the tank in no time- unless you're using creek water. Wet down, suds up and scrub, quick rinse off. Use liquid soap, as that does not have the coagulants that bar soaps do that causes scum and clog pipes. Use the washcloth to wipe off most of the water, then use a towel for the rest.
I have an article that shows how to plumb to recycle the shower water you have used. Not a bad idea for SOME folks.
