Hi,
2/3 of the switches on my electrical panel stopped working. Attached are pics of the forward and backward sides of the panel.
Switches 1 through 12 don't work and 13 through 16 do work.
Using a voltmeter I see that when I turn a faulty switch on the corresponding green light turns on (at the front of the panel) but there is no voltage on the "+" and "-" corresponding screws at the back of the panel. On a switch that works (13-16) the voltage is 13v as the voltage of the battery.
Checking the red PLUS cable that feeds the panel (on the right side of the picture) I see that there is current and the GOUND is OK too (same voltage as the battery).
I am not an electrician but it seems that on the panel itself there is a shortage that prevents current from getting to the faulty switches. Does it make sense?
Anyone experienced something similar?
Any ideas what to do?
Thanks
Yoram
Thanks
Yoram
