Has anyone come up with a magical way of installing backing plates and nuts on the transom where the space between the hull and liner is only 3/4"-1"? There is no way anything but a trained ferret could get in there.
I am mounting a ladder and do not want to bolt through the inner and outer shells because I think one side of the transom or the other will crush. I have considered drilling holes large enough to insert 1/2" pvc conduit into then filling that with epoxy and drilling a second time. Mounting it off center is not an option since the ladder will drag in the water while heeled.
