I missed pulling a cable thru when I stepped the mast. I am not taking it down again!
I saw mention of a cover plate from Rig-Rite. I'm going to order one today. I figure on using a 1 1/4" hole saw and cutting 2 holes so that I get nice curved corners top and bottom to avoid stress cracks.
I tell myself this will be a good feature if I ever upgrade the mast top electronics someday.
Electrical Access Plate: RR 72-99:
Electrical Access Plate is designed to allow access to internal electrical plugs above the mast step, without having to unstep the mast. Saves much in frustration and money by allowing you to check mast wiring connections with the mast up. SS Plate is 4 1/2" x 2" and is designed to cover a 3" x 1 1/4" vertical slot in the side of the mast, just above the top of the mast step. Plate is slightly curved to fit a variety of mast sections and attaches with (4) 1/4-20 RH machine screws (included).
