Seaward Hot Water Heater Drain Valve
Oct 1, 2007
1,865
Hi all:
Does anyone happen to know the diameter of the drain valve on the Seaward 11 Gallon water heater? I need to replace my adapter and I am not near the boat.
Thanks in advance
Rick
Oct 1, 2007
1,865
Thank you Allan. Yes, I did find the owner's manual in my googling but couldn't find the size of the drain fitting anywhere.
Thanks again.
Hunter 34 Alameda CA
Thanks again.
Rick,
You are right, it never did specify the size in the manual. From there I googled the part number and there was a marine supplier that said what it was. It's never easy.
However, I knew because my house water heater blew out the bottom last Saturday. I still had the old one in the garage waiting for pick up. I checked it and that's how I confirmed the 3/4" size. :)
