Bottom Paint
Mar 20, 2013
52
Hunter 27 MD
Did search, learned some. Previous owner put Interlux Micron Extra paint on bottom - this stuff is like $100 per QUART. #nuts
I want to start using below paint - see any issues ? Any other reasonable paints ? I'm assuming they'll all adhere to each other. Thanks !
http://www.ebay.com/itm/261815362080
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
No, they do not all adhere to one another. Check with manufacture of paint you are going to use to determine what it can be applied on.
A lot of research has been performed by the major paint companies.
Jul 7, 2004
8,496
Hunter 30T Cheney, KS
None of the Blue Water ablatives did well in Practical Sailor's tests except their 45% copper 'Copper Shield'. My guess is this medium CU content paint isn't very good.
You do need to check the compatibility of paints before you choose.
Feb 1, 2010
210
Hunter 33.5 El Dorado Lake, Kansas
I have used the Blue Water 45% copper 'Copper Shield in the past on my boats with very good luck. My old boat was done five years ago and still looks great. Used Por15 on the keel too.
Mar 29, 2017
576
Hunter 30t 9805 littlecreek
Check the content label. You pay for copper and bugaside ( made up word ) interlux label says 45% inert ingredients. And check for paint capabilities
Jul 7, 2004
8,496
Hi Amos. I'm getting ready to "POR" my keel. Right after Easter
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
Most copper-based anti fouling paints are compatible with each other. Hard paints can go over ablatives and visa versa. It's the preparation that makes the difference.
Jul 7, 2004
8,496
Don't forget to do the bottom of the keel. Make good use of the crane. It will be worth your time.
I plan to lift it and block the keel so I can work underneath . It will take two lifts. Crane is getting busy with launches.
