Sheet replacement - line type
Jul 16, 2016
75
Hunter 410 Ventura
I'm looking to replace a few pieces of running rigging on the boat. Particularly, my mainsheet is not long enough such that the mainsheet blocks bind together before the mast is all the way up. What type of line do you guys use for a mainsheet? The reading I've done seems to suggest XLS, double braid. What thickness? 1/2"? 3/8"?
Thanks!
Jun 1, 2004
8,346
On a 23 foot boat..... I'd go with 5/16 Samson yacht braid. That's what I use on my Cat 27. Nothing larger than 3/8. You want it to run through the blocks freely. You'll have to figure out the length... push the boom all the way, measure the distance and multiply by the number of sheaves plus 5-10 feet.
Sep 8, 2014
2,551
The mainsheet tackle sheaves on my C22 are sized for max 3/8" line. I could easily use 5/16, but the logic is that the larger diameter is easier on the hands for frequently handled lines. That doesn't mean go 1/2", that is huge and gets heavy on a small boat and I highly doubt your sheaves are sized for that.
Almost all of my running rigging is N.E. Ropes Sta-Set, just simple polyester cover over polyester core. For a cruiser that doesn't race that is all you really need. I check the bargin bins in the rigging section of local chandleries, they sell end spool lengths or other 'off' cuts of expensive dyneema core lines at 50% off so if it is a length and size I think I can use I have bought them. Dyneema line is kinda overkill on a small boat but it has its advantages, low stretch is nice on the halyards if you winch them up tight... I use 5/16 or 8 mm there. A low stretch Dyneema line is also nice on the Jib sheet, but that would get really expensive since I use 3/8" there (for the hands), but could also use 5/16 just as easily. Much of it is personal preference or driven by functional demand, but for our size boats you will pretty much see 1/4" for small stuff, then 5/16", and then up size to 3/8" for ease of handling but only if sheave sizes support it.
Gunni
Mar 16, 2010
5,937
Pretty much any polyester double braid is typical, this application does not warrant expensive low-stretch line. However because your mainsheet is one of the ropes you handle the most I really like a single braid like NER Regatta Braid. It is soft and super grippy in the hand, positively sticks to a winch drum, much better than a double braid. It never hockles and jams a mainsheet block.
Likes: Jackdaw
Nov 8, 2010
11,386
Yea that's the deal. Always use single braid for mainsheets, or any line that passes thru a large block-set.
-na -NA Anywhere USA
Stackwalker;
The owners manual can be found going under boat information to hunter resoursces to downloads to manual. Originally the main sheet called for 3/8 inch line 35 feet but as a dealer when purchasing I requested 40 feet. I know the boat well my friend.
