C30 Prop
Sep 29, 2015
97
Catalina 30 2188 St. Petersburg
i have repowered my Catalina 30 with a rebuilt M18 and need to replace my prop. I have a 1" shaft and want a 3 blade fixed prop. I know the diameter should be 13" but would a 11" pitch be too much?
Ted
Jan 26, 2005
1,257
Having the tip clearance, displacement, engine horsepower and transmission gear ratio will help determine proper prop specs. Contact any prop manufacturer with this information and they will be able to help you.
Lynnwood,
There were over 6,000 C30s built. You simply need to find the right forum.
Start with www.catalina30.com IIRC, it's an older site. There may be some links to skippers who have started their own more up-to-date websites.
Also, there is a C30 Google group, should be easy to find.
Good luck.
Nov 22, 2011
1,195
Ericson 26-2 San Pedro, CA
Lynnwood,
Good luck.
It's a Yahoo group.
Apr 2, 2011
185
Catalina 27 Niceville, FL
Lynnwood, I think you actually have a M-20. More torque at a lower rpm. I think a 3 blade 13x11 RH should work fine.
Sep 29, 2015
97
Donnybrook
What makes you say that? You may be right it was repowered.
