Hello,
We've been getting lots of rain the past few weeks in SF Bay, and as such I've discovered a few leaks in my recently purchased 2000 H310. By far the worst was the port side hatch. I tackled this last weekend and re-bedded the hatch using butyl tape. I've attached a picture of the core with the hatch removed. I assumed the core would be balsa, but it looks to be a foam material.
Next I need to re-bed a port side stanchion -- it's leaking badly enough that inside of the v-berth locker is consistently wet. I can't seem to locate the underside of the stanchion, however. Does anyone know if these are through-bolted? If so, it is possible to access the nuts on the underside? I have the style of stanchion indicated in the attached image.
Thanks!
Thanks!
