I modified an old boatlift for our 24 foot sailboat. I ended up adding an additional lift tank to get all the metal out of the water. It sits higher out of the water, but is stable in high winds and large wakes created by the occasional big power boat coming into the cove. The photo below was taken before the center lift tank was added. A small step ladder is needed to climb into the boat when it is on the lift at maximum height.
The most tedious part was determining the correct location on the lift so the boat sat correctly so rain water drained. We dud thus by trial and error. You want it sitting at the same level it would in the water. We are going to add some additional side bunks to help guide the boat in. Once we finalize the additional lift tank installation, we can ajust the white bow stops to place the boat in the idea location for water drainage. We have the bow a little high in this photo.
If you have any photos of your lift and of your boat hull, I might be able to suggest a few ideas.
