2007 Hunter 33 Hour meter
Oct 5, 2015
80
Hunter 33 33 Halifax
I have a 2007 Hunter 33. The Engine Hour Meter is no longer working. Has anyone experienced this and know what the issue is? Nothing showing on the display.
Thanks,
May 24, 2004
7,237
CC 30 South Florida
Cheaper to replace with one with an analog display. This one $29.95 at West Marine. The display will not fade and will give many years of service.
Likes: stuartsw
Oct 5, 2015
80
Thanks....Where did you install it? I will also try cleaning the pins on the ribbon cable in the spring. If that does not work i will have to look at adding another meter.
Has anyone opened up the enclosure to expose the ribbon cable pins. looking for some notes on how to take it apart without damaging it.
Sep 20, 2006
2,955
Oct 5, 2015
80
Excellent Scott...many thanks. I will pull the unit as soon as weather permits and start working on it.
The 2nd link has a detailed PDF on the whole repair if anyone is interested. I think i have it attached.
