Inverter location 351
Mar 20, 2016
595
Beneteau 351 WYC Whitby
Installing a 2000 watt pure sine wave inverter . Does anyone have a factory installed inverter and where was it installed. My a/c panel has location for 2nd double pole breaker with lock out.
Apr 27, 2010
970
Beneteau 352 Hull #276 Ontario
Mine is under the starboard stern cabin bed. Near the batteries. Factory Install
Mar 20, 2016
595
Thanks, is it in the same compartment as batteries or the one to stern
Apr 27, 2010
970
You have the battery compartment and to the stern you probably have an empty compartment. That's where they mounted it.
The AC disconnect is located on the AC breaker panel. These pics are not my boat.
595
Thank you ,That's where I was going to mount it. I just wanted to be sure
Cheers, Chris
