After reading over everyone's input on cooling our boat in the summer we have decided that the best way to go is to install actual marine AC. Although the most expensive option, I think in the long run it will be the least amount of hassle to get things cooled down and when we decide to sell the boat having AC will add value.
This will be a DYI project as there is no one within 100 miles that does such things. I am considering two locations, one is under the galley sink behind the electric cooler. There is ready access to the hull for the inlet and outlets plus it is close to the AC panel, it is also close to the aft cabin. The downside is that both the installation and later access to the unit for winterizing and maintenance will be difficult. The other option is under the V-berth. That area is wide open and we don't use the v-berth for anything but storage so noise will not be a factor. There is easy access to the hull but a long run to the AC panel as well as the aft cabin.
I was also looking at new vs lightly used units offered on eBay, any thoughts on that option?
Finally, if anyone has done this project are there any tips you can share? Pitfalls, cautions, anything I need to know.
