Holiday Boat Parade?
pateco
Aug 12, 2014
2,207
I have entered the Stargazer into the Pompano Beach 54th Annual Holiday Boat Parade
Went to the Captains meeting Wednesday night, and we are Boat 25.
This is the first time I have done one of these as an entrant. I am trying to make this a relaxing easy event for myself and my family/guests. We are decorating the boat this Saturday, and I am planning on using a 1200 watt quasi sine wave inverter instead of a generator. All the lights I have purchased so far are LEDs, so I should have plenty of power. Any suggestions on how to decorate, and make it a success would be greatly appreciated.
Likes: Justin_NSA
walt
Jun 1, 2007
3,556
My .02,,
I just went through this using LED 110V Christmas lights plus and inverter and ended up with about 60% of the lights some of the guys who have been doing this for a while. I had about 775 LED bulbs and the current draw through a 150 watt inverter measured on the 12V side was close to 2.6 amps. Powering this for several hours was very easy on my two six volt golf cart batteries.
Using my numbers, you can estimate your current. My current per LED bulb (through a 150W inverter and measured at the 12 volt battery) 2.6 amps / 775 bulbs = .00335 amps/bulb.
So if you end up with 1000 LED bulbs, you can ballpark your 12 volt current at 1000*.00335 = 3.35 amps. 1500 LED bulbs would be in the ball park of 1500 * .00335 = 5.025 amps. Note that even for the 1500 LED bulbs, the power at the battery side is only 5 amps * 12.5 volts = 62.5 watts. Your 1200 watt inverter will of course work fine but its serious overkill for what you likely will need. Not really a big deal however.. the larger inverter will likely result in 12 volt current a little higher than what I saw.
What most people did was use a PVC "boom" that strings of LED lights were attached to and all connected at the top. A halyard was then used to raise the LED lights sail. The 100 bulb strings worked well for boats in the 23 to 26 foot range for the "sails". My main sail was 4 strings of 100 bulb sets but a lot of the boats were using 7 or 8 strings. Ie, 700 to 800 bulbs for each "sail". You can then add whatever lights around the lifelines and rails.. etc.. We had a lot of fun doing this..
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
Will you be sailing or motoring? I think sails made up of lights would look cool. LEDs come in so many ways these days , you can be pretty creative. Don't forget to post pics!
walt
Jun 1, 2007
3,556
FYI, here is a picture of the one of the PVC booms. I got the advice to build it in your driveway then take it to the boat. The "sails" are now all rolled up around the PVC pipe hanging in the garage waiting for next year. This particular boat had a bare boom but a bunch of the boats just tied the PVC boom to the main sail in the bag
This picture was taken just before everyone left the marina
Likes: pateco
pateco
Aug 12, 2014
2,207
Motoring
Dec 19, 2014
57
Tartan 30 Baltimore
Just did our first parade last weekend. It may be too late for you but I found 166' strings of 12 volt LED lights and ran them off a spare battery I had at the house. I ran out of time converting the 12 volt blow up Santa and Rudolph to bypass the 110 power packs so I just plugged them into my 400 watt inverter. They both only draw 2 amps each so it worked fine. I'll convert them to straight 12 volts and connect them to the battery for next year. It was a lot of fun and I'm already working on ideas for next year.
It was a ridiculously windy day so we only ran a string of lights up the backstay and down the headstay, and around the lifelines. We had a 9ft blow up Santa standing on the boom and a 4 ft blow up Rudolph leading the way off the bow pulpit.
I had planned on making a tree shape but it was just too windy to pull all that together in time. We were a little under-decorated compared to most of the powerboats and some of the more seasoned sailboats but we still got pretty good reviews.
Have a blast!
Likes: pateco
Kermit
Jul 31, 2010
5,722
Lots of good ideas on the technical aspects. Here's my take on aesthetics. Sometimes less is more. It seems clear to me that you won't outshine anyone with quantities. Why not try for "Classy-Minimalist" this year? Keep in mind that setup takes longer than you think it will. Plus the entire aparatus will take up space from your family and guests. Plus there's the extra attention it will require on your part. Whatever you do it needs to be fun for everyone onboard. And it's entirely possible you'll get noticed for being different - but in a "Classy-Minimalist" way. Good luck and have fun.
Merry Christmas!
Jul 7, 2004
8,542
People are doing neat things with coordinating lights to music too.
Not the Griswalds, but impressive
pateco
Aug 12, 2014
2,207
Merry Christmas!
Definitely going with the classy simple look. Cant afford the digital lighting effects (they are cool but too pricey even for my house), and I don't have deck space for any inflatables.
I may just do fore-stay, back-stay, mast, boom, and lifelines. If I have enough lights I may try to do a light sail for the main. When I run out of lights and $ I will know.
Any good hints on how to do lifelines? I'm thinking zip ties, but I have seen them wrapped
Kermit
Jul 31, 2010
5,722
I heard someone on VHF refer to me as Clark Griswald on the 4th. One man's ceiling is another man's floor I suppose.
How about draping the lifelines? You'll probably find that the length won't be perfect. So do what seems to work out the best. I'm serious about it taking more effort than you realize. My wife seems to like the effect but doesn't like the bother of setting things up. Make it fun above all else.
pateco
Aug 12, 2014
2,207
The inverter worked great. the lights seemed to only pull about 2 amps total off the alternator, but when I turned on the PA Amplifier and mixer for our music, we were drawing a little over 10 amps, the 55 amp alternator kept up at that level nicely. I don't think we had 1000 bulbs.
Dec 28, 2010
462
Catalina 380 san pedro
Marke 14...that boat is in a slip a couple down from my boat. The folks are really nice too. Kermit looks better by day tho.
pateco
Aug 12, 2014
2,207
A friend shared some more pictures of the Stargazer with me.
Now if I could just get a copy of the Drone Video that was obviously being shot of my boat in the above picture. LOL
