Going from 20 gauge wire to 14 gauge wiring
May 23, 2004
3,319
When I re-wired my mast I ran 14 gauge duplex wire to the top of the mast for the anchor light. My anchor light is an extremely small wire, 20 gauge).
What would be the best way to go from the anchor light at 20 gauge to the 14 gauge wire?
May 23, 2004
3,319
Thanks for the quick reply. I just ordered some with West Advantage Reward Points so they were free!
RoyS
Jun 3, 2012
1,742
$7.95 each? What I usually do is use the larger size butt connector, in this case 14 gauge, and double back the stripped end of the smaller gauge wire until the smaller wire fits the connector, then crimp. This may not be an approved method but I have never had any problems with it. This also works for joining three wires with a single butt connector.
Jul 7, 2004
8,534
Hunter 30T Cheney, KS
This.
I was advised on this forum to use 16ga in the mast for strength and that's what I just did last weekend. 14 ga will be plenty! I'm using 20ga from the terminal board in the ceiling to the control panel.
I hope you converted to LED while you were able to get to the mast top.
Beneteau 323 Annapolis MD
[QUOTE="Justin_...I was advised on this forum to use 16ga in the mast for strength and that's what I just did last weekend. 14 ga will be plenty! I'm using 20ga from the terminal board in the ceiling to the control panel....QUOTE]
My 2 Cents::: If someone told you to go up one size from 14, you went in the wrong direction. My opinion is, nothing smaller (larger number ) than 14 is a no-no on my boat unless it's part of the fixture.
Jul 7, 2004
8,534
It was MainSail's advice among others. I trust his judgement. I also clamped it at the top.
Dec 2, 1999
15,184
I see you got what you needed. In the future you may want to check out Del City . com for some of your electrical needs.
May 23, 2004
3,319
The wire coming out of the LED anchor light is 20 gauge. I really don't like that. I realized that LED uses really low voltage but I prefer heavier wire.
I ran 14 gauge for strength etc.
I will see how this anchor light does this next coming season. If it works well it will stay. If it doesn't then I may go with the other anchor light posted in this thread that is the white or tri color.
Jul 7, 2004
8,534
20ga is fine for current (electrical) requirements. If you're worried about breakage, do what I did and clamp the new wire attached to it. The newer fixture will be light gauge wire too.
