I know there are not many C275's out there and the ones that are, seem to not hang around the forums. Anyway, I've had one since June 2014 so I can hopefully answer some of your questions. Not sure if there is much to modify, but most of my modifications were for the inside of the boat and being a Catalina, you pretty much have to do them after purchase. Anyway, regarding the sails, I have the stock Doyle sails. They're not bad, but they are not true expensive racing sails. The self-tacking jib is really not for racing. Anything but close hauled, the top half completely twists off. But for daysailing it's fine and also really nice when solo. Further, my self-tacking jib was cut too tall and max'd out against the mast causing the halyard to wear and snap on the last sail of the year. Obviously, the spinnaker is a must but being asymmetric, you will not point as far downwind as a symmetric. If you are more specific as to the modifications you are considering, I may be able to give a more directed answer. Also, I'm not sure if you have been on a C275, but don't get fooled by "Sport" being in the name. It may have some nice hardware, but it's too heavy to be a sport boat and Catalina is not being honest when they say it comes in at 5000 lbs. That being said, I'm happy with the C275 and I'm so thankful that my C270 purchase in 2013 fell through.How was your racing season? Did you make any boat modifications? I am planning to purchase a Catalina 275 Sport this winter and plan to race next season.
Sorry do not have the information you require. The only info in the manual is 676 sf. for the spinnaker. Doyle makes the main and jib, so you may want to contact Doyle in Florida to see if they made the spinnaker and they would have the info you need. I only have the 100% jib which is 145 sf. (the 106% is 175 sf., main is 242 sf.). Because of the self-tacking track with the 100%, you can not go straight downwind without securing it out, which I have never done. If I was racing, I would be using the spinnaker. Pleasure sailing, I don't go straight downwind or I roll in the jib. Don't know how long a J-length pole is, but these sails are on the smaller side.Do you happen to have the measurements of the stock C275 Sport asymmetrical spinnaker? I need the measurements to apply for a PHRF rating. Measurements of the luff, leach and mid-section girth are required. When racing non-spin, do you pole out the genoa? If so, do you use a J-length pole?
I think the C275 is a cool boat.Do you happen to have the measurements of the stock C275 Sport asymmetrical spinnaker? I need the measurements to apply for a PHRF rating. Measurements of the luff, leach and mid-section girth are required. When racing non-spin, do you pole out the genoa? If so, do you use a J-length pole?
Throw that thing on a trailer and come on down to Chicago. I'll spar with you all you want. You should go better upwind than me because of my shoal keel and smaller jib, but that's ok. I think the biggest problem with the speed of the C275 (and I'm not an expert) is that it is too heavy to really scoot when it is windy and it has too much wetted surface in the light stuff. How do you like your Quantum sail? I'm making the assumption that is not a self-tacking jib. So with that in mind, do you change your jibs depending if you are racing or not? I would like a better jib, but I'm not that motivated because I like the ease of the self-tacking when solo.Its hard to tune a boat without a twin or reasonably similar boat to spar with. Is there a way to contact all the 275 owners? How many boats have been sold? (not just built). My luring curve on Hobie's and DN's was sped up considerably with help from other skippers. If your out there lets talk!!
Better yet, you should throw yours on a trailer and spend a week on Leech Lake. This photo is from The Chase on Walker Bay (the tiny end of the lake). The horizon you see is looking north towards the end of the "tiny" bay. The main body of the lake isn't even in the picture. You could easily spend more than a week exploring this lake. We were in Walker for a wedding in early October. Most sailboats were out of the water by then, leaving the lake to walleye fishermen!Throw that thing on a trailer and come on down to Chicago. I'll spar with you all you want.
I'm sure it would be fun gunkholing around up there. But if I was going through the trouble ofBetter yet, you should throw yours on a trailer and spend a week on Leech Lake.
Ha! They did a good job at disguising the roof of the bar/restaurant! We had a great view of the lake from a really nice suite, but for the price, nobody would want to look at an ugly roof! They even have benches up there, but I couldn't find any access. I think they have to climb thru the port in the center of the roof.Had to laugh at the picture, looks like they could set up a putt-putt golf course up on the roof.
Small world. I taught sailing there from 1980 to 1983 and actively raced Hobie 16's until WSA died.I know Lake Michigan pretty well ... much of my youth was spent at Gillson Park beach, and I sailed my Hobie 16 from there on a few occasions for Hobie regattas they had back in the 80's.
You have polars? Can you share with the class? ;^)The C275 points well. It goes to weather well. I had Quantum sails make me a "Race" jib. (Ok technically a genoa) . Nice shape. not much bigger than the self tacking Doyle. But as big as the rig allows...the leach almost touches the spreaders. it uses the tracks/lead blocks so adjusting sail shape is possible. But it docent help much off the wind. The irony is what when I raced Hobies I excelled at down wind runs. I did get the polars and attempt to use the info. I agree that if I put her on a trailer I am going a lot further south than Chicago. (Sorry....) Still looking for ways to go faster!!
